Lightning causing led bulb power effect
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    This happened as my sister described it. Their new house has an open walkway to the garage, and one, what she is sure is an led bulb. She said when there was lighting near it would momentarily light up, and make a popping sound.
    I explained, off the top of my head that the driver circut probably has a transformer that is effected by the lightning creating a temporary flow to the led. This is an assumption and would like your opinons
    Their house is I think 100% led lights but just the bulb outside in the open area does it.
    Could find nothing on google as most results were relating to other things
    Am I anywhere near right on this?
    Fyi the bulb is on a simple switch, no digital controls
    • 31140
    Re: Lightning causing led bulb power effect
    the cable-run to it is probably acting as the antenna.
    i'm not sure i'd trust it if it made a "pop" though - maybe the electrolytic burst!!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Did she have a little too much wine when observing this? I've never heard of such a scenario (the popping)..... Mainly, I don't see the driver being able to take such surges and survive....but stranger things have happened. At some point, you need to autopsy the bulb and see what's in it.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8286
        Sounds almost like a grounding problem. Get her to make a picture of the bulb. Some cheap Chinese leds that have capacitive droppers are easy light up.
        • redwire
          • Dec 2010
          • 3912
          I have seen a ghost flashing LED fixture when power was off.
          It turned out to be the on/off switch was switching neutral, not hot.
          So the LED bulb's power supply always had hot (but not neutral) at the AC input and any stray capacitance to ground (on the floating neutral return) or antenna action is enough to charge up the LED bulb's cap and blink once in a while.
          In Nomex cable, there is capacitance to the GND conductor.
          Some LED bulbs use no SMPS, just a CC source inside and they light up with microamps. The SMPS bulbs will blink every minute or so.
          So any mains spike would make the LED bulb blink due to capacitive coupling, if this is the wiring issue.
          I would be worried about the 'pop' sound- that could only be an arc from a mains spike? There must be a problem with failed insulation?
            • 31140
            well leds are current-drive so it's possible that several hundred or even thousand volts lit the led and blew the small output cap.
            for ghost leds ElectroBoom had a video.
            https://www.youtube.com/watch?v=_bgUy6zA0ts
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8286
              Right on stj. That's the vid I was thinking about.
                • Jul 2011
                • 6057
                This guy is real funny and crazy he does real stupid sh*t
                But he does explain it very well
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
                • ezenia
                  LUMIMAN Smart Bulb IC ID?
                  by ezenia
                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                  04-28-2025, 05:56 PM
                • JimBanville
                  Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                  by JimBanville
                  I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                  Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                  01-24-2023, 07:49 AM
                • zoltor
                  Canon G3430 has a lightning flash after the firmware
                  by zoltor
                  Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
                  Yesterday, 12:40 AM
                • Bardou Kari
                  HP EliteBook 840 G6 – no power after lightning strike
                  by Bardou Kari
                  I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                  – Charger is OK and 19V is present at the motherboard.
                  – No charging LED, no fan, no reaction.
                  – I don’t see any 3.3V or 5V near the coils.
                  – Battery is unplugged.
                  – I’m new to board repair but can use a multimeter.
                  I added a clear photo of the board.
                  Any idea where to start or what to check next?
                  Thanks a lot for your help!...
                  07-01-2025, 10:45 AM
