BRD file structure
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    BRD file structure
    I don't know if this is the correct place to ask about boardview software but
    I'm trying to figure out how openboardview software works; at the moment I'm concentrating on first version on visual c++ 2019.
    before analyzing the structure of the application I would like to understand the meaning of the data contained in a brd file
    I have decoded this format with using a code taken from github, I don't know if the result is correct but
    I have decoded this file (LB# 820-2879 ''Board View'' file.brd) and I think it should contain the following data:
    1 - number of component on a board
    2 - coordinate to locate the single component, the test point, etc
    3 - the component type, for example SOT23, SOT323, etc
    4 - the number of pins for each component
    5 - connections (net) between a pin to another pin
    etc
    I know the imgui is used to manage the graphics but I don't see any info about the type of component to draw
    In the picture I post, there is an extract of the decode BRD file (apple), someone can hel me to understand
    the structure of the file?
    thanks
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: BRD file structure
    @piernov know about this many as i know
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      I know, but I didn't want to disturb him in private, I hope he gives me the information I'm looking for
        • 31144
        ask paul daniels - he regularly livestreams on youtube.
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
            07-23-2023, 07:39 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • EbrahimSiami
            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
            by EbrahimSiami
            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
            **What I have tried so far:**
            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
            07-02-2025, 02:31 PM
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
