Can I convert the head of a 250v plug to 110v?
  • caphair
    • Nov 2011
    • 1249
    Purchased a heating platform for repairing iPhone X models. It’s compatible with both 110/250v but they sent me the 250v plug and won’t respond to my messages to have the correct plug sent.
    The plug isn’t built into it, just plugs in with special connector which is how it’s compatible with both systems. Could I simply cut the 250v head and splice in a 110v plug or simply use an adapter like this? European Adapter, Fosmon Type C EU to USA & Canada Travel Adapter Plug, 2 Prong Universal Power Converter (Black) https://www.amazon.com/dp/B072F91W38..._LSIFDbA1D8ZR4
    It’s just a heater with no real electronics so not sure if current draw is different and wire could potentially get too hot
    • Jul 2011
    • 6070
    Re: Can I convert the head of a 250v plug to 110v?
    What does the heater say about the voltage range and does it have a switching power supply
    Or
    Is it just a heater element with a thermostat
    If it what have above and it just a heater with a thermostat then maybe or maybe not
    It depends on what type of heater element it has to weather or not it will work or not
    The heat up time might be longer and will it get hot enough for you to use it
      • 31283
      you can chop it, but if the device is just a heater it will take longer to heat up at 110v
      • caphair
        • Nov 2011
        • 1249
        I believe it's just a heater. Doesn't look like there's much to this. Just a copper plate and the plug has a little box with an on/off switch
          • 31283
          probably a ptc based design like in hotglue guns.
          • caphair
            • Nov 2011
            • 1249
            So just an adapter will do? Does it self regulate temp?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8707
              PTCs self regulate -- sort of. They'll stop drawing power when they reach their temperature.
              Question is - what's in the box(es)?
              Keep in mind that halving the voltage quarters the heating so you may have to wait a very long time... if it doesn't lose more heat than it generates at its temperature...
                • Jul 2011
                • 6070
                This might be where you take the cover off of the blue box and see what is inside and maybe show some pictures of what is inside
                • caphair
                  • Nov 2011
                  • 1249
                  I’ll have to take it apart when I get a chance.
                  The specs say 110-250v and reaches 183c in 3 minutes. Curious if that 3 mins is for the 110v version or if that’s the same for any voltage
                  • caphair
                    • Nov 2011
                    • 1249
                    The seller finally responded and said an adapter not converter should have been included for 110v and they’re sending one. Thanks for your help guys
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      The TV does not turn on, the standby indicator is on. All voltages are present.
                      Emms is dead. Not readable, not detected.
                      Replaced emmc.
                      But with another dump there is no launch
                      Terminal log
                      UART
                      AC_ON
                      RPMB key is not yet programmed
                      HASH1_VERSION=0x00000000 64bit
                      E-B
                      FDE enabled
                      layout pattern onebin by SAR7,0...
                      06-01-2025, 02:11 AM
                      HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                      This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                      09-06-2024, 11:17 AM
                    • sew333
                      Can i plug pc on this apartment with older fuse box?
                      by sew333
                      Hello. I will be buying new apartment to live. But fuse box is older. Not the newest.
                      And my question. It will be fine to plug pc in this new apartment with that fuse box,i think it is aluminium,right?
                      PC WILL BE: Rtx 4090,14900K,1600W PSU
                      It looks like this ( screen from internet ). Looks like this,not sure i dont take a pic from there. Can i plug pc with that one?
                      screen of this:
                      room:
                      Someone said this to me.
                      1
                      "I would get advice from a local electrician...
                      03-29-2024, 05:37 PM
                    • Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                      by Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                      03-15-2024, 09:37 AM
                    • Arashiak
                      QY6-8002 Canon 2410 2010 inkjet (head pinout) HELPPPP eeprom
                      by Arashiak
                      Dear all friends
                      I am going to read the eeprom inside this printer head i need some help from some expert that work with the canon printers
                      1. what chip they use inside the head that i mention in title?
                      2. Is there anyone helping me identifying the pinout
                      Thanks in advance to all the people that cooperate and Badcaps.net staff.
                      05-26-2025, 06:09 PM
