SMD Memory chip identification
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Has anybody came across a memory chip like this? Is there a way to decode what this is in order to read it?
    All it says on it is "Y" in the corner then "5CAY" under that.
    I tried to read it like a generic 25 series memory but it returned gibberish.
    • 31157
    Re: SMD Memory chip identification
    what is it in?
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      From a specialized machine, it counts work hours and cycles of machine part, kinda like toner cartridge chip if you say
        • 31157
        could be a similar chip to car dashboards,
        they contain an eeprom based counter that can only go up - although there are programmers that can reset it somehow.
        • R_J
          • 9580
          The ic could be a microwire, that's why it could not be read. my guess is a custom number, tracing out the pins might give an idea as to what it is.
            • 31157
            35 or 95 series.
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • shovenose
              NVIDIA GPU Memory Chip ID and Replacement
              by shovenose
              I'm trying to repair a GTX Titan X, seems to have a bad memory chip. I have this random graphic I found online but my card is double sided, does that matter? And based on the test result, which one do I need to swap?
              I am using a Tesla M40 12GB as a donor board, model number of memory chips on that one is really hard to read but I think they are the same.
              As for actually swapping a memory chip from the donor board, I have never done any BGA work before. I watched this video https://www.youtube.com/watch?v=goViV2IYogk and it seems he is using a new memory chip, vs...
              01-21-2023, 12:51 AM
            • kokodin
              memory mod for amd radeon r7 260x
              by kokodin
              Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
              I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
              In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
              03-28-2024, 03:48 PM
            • Jonny_Doe
              Artefacting / locking R7 370 - bad memory chip identification
              by Jonny_Doe
              Hello everyone.
              My son came to me one day saying that his pc locks up.
              I found his onboard sound and gpu not working.
              The gpu is an R7 370 and it has weird colors in bios and locks hard when windows/linux loads a driver for it.
              I have run a diagnostic utility (a linux based app with mats/mods for nvidia and tserver/memfa for AMD) and it spew out some things.
              It says error on ch7 rank 0 bit 14.
              Now, i have no idea which of the 8 chips is ch7.
              There are 4 chips arranged vertically to the right of the gpu and 4 horizontally...
              02-10-2022, 10:36 AM
