Help to identify SMD Zener diode
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I have this Zener diode that is open.
    I took pictures before desoldering it, I have attached them here.
    Can anyone tell what Zener voltage this has from the markings?
    I have an idea but don't want to cloud the opinions so I'll wait for what you say...
    • 31011
    Re: Help to identify SMD Zener diode
    5v1 zener or a 7v tvs in my book.
    • redwire
      • 3907
      Not sure if SOD-123 or SOD-323 package.
      Diodes Inc DDZ5V1BS SOD-323
      Diodes Inc DDZ5V1B SOD-123
      It used to be a Zetex part.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        probably get an educated guess from where it is fitted in the circuit . tvs would test open as a diode . is there another the same in the unit ?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Thanks, yes this is the same as I figured, it seems to match SOD-123 physically and that it infact is a Diodes Inc DDZ5V1B (5.1v Zenerdiode with 0.5w rating)
          What threw me off was a Youtube video where in the comments people wrote it was a 5.2v Zener, but seeing how uncommon those are I doubted it...
          I'm glad you all agree
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Posting this here also for future reference, it's from the datasheet.
            The date code marking is B5 (May 2014) and this matches well with other components on the PCB.
            The zener diode model marking is KM (DDZ5V1B)
            • hobostove
              Corsair RM1000e - Help identify 5VSB Zener diode
              by hobostove
              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
              There's a 22ohm resistor that's melted and open, but it still has the bands.
              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
              It looks like the diode connects the source and drain of a TNY284...
              03-27-2025, 02:25 PM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
            • nev1001
              What zener diode might fix the sound on Maestro Mayhem gaming chair?
              by nev1001
              Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
              The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
              It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
              I think an issue could be a zener diode (or capacitor) which has shorted out.
              The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
              04-17-2025, 05:09 PM
            • Vincenzo2
              Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
              by Vincenzo2
              My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
              Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
              I put some pictures here to show that it is labeled "M7"....
              09-07-2023, 07:43 PM
