Diode Test
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Diode Test
    Argh, I lost my long post, damn Firefox, that's what I get for not using Opera!
    Gianni; Thank you very much for your help
    Some clarification from my end, I think I know what went wrong
    I do not have a lab PSU, but the first thing I tried doing was to isolate the circuit, I did this by removing the resistors L1 & L2, and cutting the trace next to them
    The switching chip still saw some voltage tho, ca 0.5v...
    After this I tried lifting the diode instead, after reconnecting the trace and resistors
    This resulted in the Ethernet Chip becoming alive and doing it's diagnostics test with it's LED's
    However the small FET also became very hot, 150°C or so (As is still evident by the burn mark on my index finger lol )
    At this point the ethernet chip got the voltage I think it was supposed to get, 3.2VDC measured on L1 & L2
    When I lifted the FET the ethernet chip became dead, it again only saw 0.5v
    But I think my continued testing with the FET caused it to short internally, so the Ethernet chip received whatever the FET had on it's input side, and not the 3.2VDC it was supposed to have...
    So had I just changed the FET originally I think the switch would have worked, but alas now I think there is no meaning to it, I have probably fried it with my testing
    But I thank you very much for your help, it has still been a valuable learning experience!
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Re: Diode Test
      This voltage seems more standard than 2.29V but from calculation it should be 2.29V unless I'm missing something.
      This is correct as I wrote before anyway the voltage should be 0V not 0.5V.
      From your pics I see L6 and L5 closed to the input connector, than I see L4: I think L4 and C118 are the input filter for the step-down converter and probably from L5 there is a tracks feeding other parts of the board.
      I think L4 and C118 avoid ripple/noise propagation from the converter to the main input voltage and other circuit.
      You can check it with your DMM between Drain and Source, it must be open. If you test in "diode mode" you should measure the body diode (Drain= anode Source= cathode) probably between 0.5~0.7V.
      Ok if it is shorted than then input voltage went directly to the circuit and probably has damaged it.
      You started in the right way but without an oscilloscope it is hard to understand what's going on. With the converter disconnected you should have measured the output voltage (2.29V) but probably it was already damaged since the output was 0.5V.
      Ciao
      Gianni
      "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
      H. J. Brown
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • chth96
        How Can I test PWM DM0365R?
        by chth96
        Hello
        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
        06-18-2025, 04:14 PM
