Running a microcontroller in car - power supply aspects
    replied
    Re: Running a microcontroller in car - power supply aspects
    hell no,
    start with 6502 - get yourself a commodore64.
  • Curious.George
    replied
    Originally posted by Dannyx
    Yeah, I've got some massive learning to do...that went way over my head really quickly Bits and registers and stuff...
    I may also have to learn something about PICs in the future, having come across one in a control panel for one of those pump systems I talked about in another thread...we know nothing about what's on there and how it works yet, so that will be my job...
    PICs are a lousy place to start as their architecture is really quirky.
    If you have NO experience with CPUs/software, your best bet is to pick one of the "classic" processors (1970-80 vintage) with more regular instruction sets and programmer models to "cut your teeth on".
    If you could find a copy of the 6800 Microprocessor Applications Manual (that's 6800 not 68000!) it can almost act as a textbook to expose you to the issues you'd need to know. It's long but is an easy read.
    Caxton Foster's (poorly named) Real-Time Programming is another quick read.
  • Dannyx
    replied
  • Curious.George
    replied
    Originally posted by redwire
    If I am (wrongly) globally shutting off interrupts, the Arduino libraries must overwrite that, as I get serial I/O fine after waking up from sleep.
    Dunno as I have no experience with that hardware nor the "system" software.
    If you have access to ALL of the sources, you might try to search for "GIMSK" anywhere in them and manually examine each such reference to see when it may be taking effect.
    [One problem with MOST software is there's never a useful "roadmap" that lets you figure out WHERE to look when you have a problem.]
    The other thing you can try (brute force) is littering YOUR code with tests to check the value of GIMSK at convenient places. And, whenever it "looks significant", emit a message, blink a light, HALT the processor (so you can figure out WHERE the test came back "positive").
    [I don't know what sort of debug environment you have available]
  • redwire
    replied
    I think you're right, I looked at the code and it would never shut off the pin-change interrupt on the Ignition switch input. It's been in the car for 2 years with no fatal troubles (i.e. dead car battery). The only thing I've noticed is if the MCU (accessory timer) is running and then I start the car, sometimes the stereo will cut out and then reboot- which I attributed to my old car battery dropping too low during cranking. But that might be an ignition off->on->off (during cranking)->on (engine running). Three pin change interrupts.
  • Curious.George
    replied
    Those are bit-set and bit-clear instructions directly to MCU registers. What you are doing is reading the register, OR'ing 1 with the bit you want to (set) to a 1 (or AND'ing 0 with the bit you want to (clear) to a 0), and then writing that result back to the register. So you leave all other bits in the register alone, just bump the one you are interested in.
    I understand that's what you THOUGHT you were doing. But, in practice, you're NOT!
    PCIE is the 5th bit position of GIMSK, "pin change interrupt enable bit"
    If PCIE is actually defined to be "5" (and not 00100000r2 = 0x20), then:
    GIMSK &= (0 << PCIE)
    is actually:
    GIMSK = GIMSK & (0 << 5)
    which is:
    GIMSK = GIMSK & 0
    // 0 shifted left 5 times is still 0
    which is:
    GIMSK = 0
    (i.e., each bit in GIMSK is anded with a 0, yielding a 0 in that bit position)
    Again, assuming PCIE is "5", the second quoted line is correct:
    GIMSK |= (1 << PCIE)
    is actually:
    GIMSK = GIMSK | (1 << 5)
    which is:
    GIMSK = GIMSK | 0x20
    which ensures "bit 5" is set in GIMSK regardless of whether or not it was set (or clear!) previously.
    The FIRST line of code should have been:
    GIMSK &= ~(1 << PCIE)
    which is:
    GIMSK = GIMSK & ~(1 << 5)
    which is:
    GIMSK = GIMSK & ~(0x20)
    // 0x20 is 00100000r2
    which is:
    GIMSK = GIMSK & 0xDF
    // 0xDF = 0x11011111
    In other words, "ensure bit 5 is clear regardless of whether it was set (or clear) previously."
    You can test this with a trivial program:
    // ensure ALL bits are set just so we can see which one(s) change
    foo = 0xFF;
    foo &= (0 << 5);
    printf("Foo is %d.\n", foo);
    foo = 0xFF;
    foo &= ~(1 << 5);
    printf("Second foo is %d.\n", foo);
  • redwire
    replied
    The Arduino IDE has all the MCU registers (for ATmega328 or ATtiny85 etc.) defined internally I think in <avr/io.h>. All capital letters are traditionally used for constants.
    For the ATtiny85:
    GIMSK is the MCU General Interrupt Mask Register at address 0x3B, and within it is
    PCMSK is the MCU Pin Change Mask Register, selects which pin(s) will generate a pin change interrupt.
    sorta explained here: https://thewanderingengineer.com/201...s-on-attiny85/
    Doing the same with the ATmega328:
    PCICR is the MCU Pin Change Interrupt Control Register, choose the port A,B or C.
    PCMSK2 is the MCU Pin Change Mask Register, choose which pin(s) will generate a pin change interrupt.
    example here: https://thewanderingengineer.com/201...ge-interrupts/
    In a nutshell, just turning on pin-change interrupts for the pin, the port, the CPU. So when the MCU is asleep, it gets woken up by the Ignition pin going from low-> high (DannyX is opto inverted so high->low).
  • Curious.George
    replied
    Code:
    8<
     GIMSK &= (0 << PCIE); // no more Pin Change interrupts; mask them off
    [B]What do you think THIS ^ does?[/B]
    8<
     GIMSK |= (1 << PCIE); // unmask Pin Change interrupts; Interrupt source
    [B]This suggests PCIE is a small integer[/B] (I don't use those processors)
  • redwire
    replied
    It is easier to write software by breaking it down into little pieces. You can write out pseudo-code as it is called, just to nail down the big picture.
    Then, you drill down into each piece, and do the hard work of coding a little chunk at a time. (in all truth, I only use 'state-machine' code for all Arduino projects now, it's what the pro's use, so much less pain)
  • Dannyx
    replied
    Looks awfully complex...haven't looked into it yet, so maybe I'll pull it off...registers and in-depth stuff go a bit over my head
  • redwire
    replied
    Here are snippets of my Arduino code. There is an AVR sleep library.
    First, I have a pin change interrupt (on IGN and pushbutton input) to allow wakeup even though the MCU is asleep.
    To go to sleep, I shut off the A/D and analog comparator to save power, and enable the pin change interrupt.
    Code:
    #include <avr/sleep.h>
    // these snippets for ATtiny85
    ISR(PCINT0_vect) { // Pin Change Interrupt
    // GIFR automatically cleared here; hope timers don't use them
    // clear the pin change interrupts and turn them off
    // good to wake and run now; or no change during normal interrupt
     sleep_disable(); // now that we've woken up, stay up;
     DEBUG_PRINTLN("**int WAKE ***");
     state=sWAKE_FROM_SLEEP; // duplicate - in case we (return) wake up in lala land
    void SleepSession(void) {
     // configure and enter sleep mode, only pin change interrupt (ign switch or pushbutton press) wakes us
     ADCSRA &= ~_BV(ADEN); // disable ADC and save power ~0.3mA at 5V; _BV is a macro
     // not sure if BOD (fuse) is used, analog comparator if used may need to disconnect too to save power.
     // config pin change interrupts
     cli(); // disable global interrupts as we are reconfiguring them
     PCMSK = 0b00011000;  // unmask pin change interrupts on pins PB3, PB4- the switch inputs
     // not sure if timer interrupts happen on Arduino with Attiny85, leave otehrs alone
     set_sleep_mode(SLEEP_MODE_PWR_DOWN);
     sleep_enable();
     sei();         // re-enable global interrupts, sleep is set up now
     sleep_cpu(); // go to sleep
     //---------------------- W A K E ---------
     /* Upon waking, the program will continue from here. */
     state=sWAKE_FROM_SLEEP; // ensure we go to the correct next state
    replied
    it's in the cpu, not sure if arduino language has it - but it probably does.
    or just hit the registers directly to lower the clock or shutdown sections of the chip
  • Dannyx
    replied
    I'm planning on using the sleep feature as well. This thing is listening for a lock/unlock signal and acting accordingly, so why not have the MCU sleep when it's doing nothing ? I hope it can be done, that is, "wake" the MCU when one of its pins acts (car is locked/unlocked).
  • redwire
    replied
    Ahhh much better current drain You need that extra 4mA for the MCU
    I made a car key-off timer with ATtiny85 with LP2951, to charge phone or listen to stereo for 3hrs if you push a button or key-off. If I stall and restart my engine, it would always reboot the stereo (which takes a long time) so I wanted a battery-power feed to stop that. IGN wire always cuts out when you crank.
    What I do is wake up the MCU when the ignition key goes on, and after, I wait 30 seconds and put the MCU to sleep. This saved a lot of current. The A/D I don't use but that section draws a lot of current so I switch it off.
    MCU running at 1MHz (A/D off) it was 2mA (plus LED) and going to sleep 0.02mA plus the LP2951, which gives 0.12mA when sleeping. I mention it because it could be something to consider adding to your code, the sleep function. Or shutting off the A/D and Hall sensors when you are not using them.
    But maybe your current drain numbers will be good enough. Just giving ideas.
  • Dannyx
    replied
    Sorted. It turns out the zener diode ZD7 was clamping too low for some reason, causing excess current drain. I removed it and replaced it and it's now working as it should
    I also installed the polyfuse, so this whole thing is ready to be tested on the car now
  • Dannyx
    replied
    I came up with an idea to try and track down the part that's drawing spurious current without having to tear the traces apart: I started by removing the IC and optocouplers from their sockets, since it was the easiest thing to do. I then supplied 5v to the "regulated" output of the IC from an external PSU and measured the current draw on that - 4mA are still there, so it's not the IC, nor something on the 12v side.
    I then tried out each type of component individually with the power supply, by using an identical one from my parts bin and placing it in series with the bench supply and my ammeter, including the three types of caps and the 5.1v zener diode. None drew any current at all. The zener diode starts breaking down at around 5.5v, as a side note, which is great news because that's the maximum the Arduino's VCC pin can take.
    I then supplied 5v after those pull-up resistors, to confirm whether it's those ceramic caps that draw current, since they were the only part remaining on the board, but no they're not: I get no current draw here at all ! With all said and done, my money is on the small 10uF electrolytic or tantalum cap on the 5v rail (on the output pin of the IC), although I tested these individually and neither drew any current at all ! I must admit the idea of placing two types of caps of the same value (10uF) on the output of the IC is an undocumented/unfounded idea of mine that I came up with on my own, fearing a single electrolytic may fail due to the hot environment and result in the output overshooting (having seen what the IC does with NO cap at all >> 10v on the output !), so the more professional folks out there may be quick to pan this, but hey - learning
  • Dannyx
    replied
    Originally posted by stj
    it's probably going through the pullup-resistors
    Yes, but they aren't connected to the Arduino ATM (because it's not inserted)...unless the optocoupler + the ceramic cap has leakage, which is to be expected...
    replied
  • Dannyx
    replied
    Just try pull the Vreg IC out of the socket, then you can see if it is ahaed or after, the current drain.
    I find chinese electrolytics have high leakage currents.
    I'll remove the IC and supply 5v directly with an adapter or something and measure the current draw on that. It'd be great if it's just the cap, since I can easily remove it and replace it (hopefully with something better quality)....
  • redwire
    replied
  • CG2
    Meaco Arete One / Deye Dehumidifier not working
    by CG2
    I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
    Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
    08-17-2024, 07:47 AM
  • Kambi13
    Samsung NP370E4K No backlight running on battery
    by Kambi13
    Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
    Tried different battery - no change
    Tried different screen - no change
    Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
    09-04-2023, 11:06 AM
  • Dannyx
    "Kinetic" 433Mhz transmitter/receiver discussion
    by Dannyx
    Good day folks.
    TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
    Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
    03-08-2022, 11:01 AM
  • Skgod
    Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
    by Skgod
    Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
    Black screen, freeze
    The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
    When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
    So can anyone tell me what would be the possible cause?...
    10-16-2024, 08:11 PM
  • FALKLAN
    Running Line Voltage and Integrating LED Pods - Automotive
    by FALKLAN
    Howdy everyone! I hope all is well where ever you are!
    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
    02-05-2025, 12:30 AM
