Help identifying a chip
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Hopefully this is the right place to post this.
    I've been searching for days trying to find out what this chip is called. I know what it does but searching to buy a replacement is impossible, could anyone help me in identifying it so I can buy replacements?
    It's a driver that powers mosfets on a graphics card and that's all I know about it. Any help would be appreciated I've attached a picture of it.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Help identifying a chip
    Afraid I can't help with finding what that chip is (my research for these things is not so good).
    That aside, if this chip is for an ATI Radeon HD, R7/9, or RX graphics card with shorted MOSFET(s), don't waste your time - GPU is probably shorted and dead.
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      I've been searching for a while. I think it's the fact it has an = sign on the chip that throws off the search results.
      It's from a gtx 980, I'm fairly sure the gpu is good but it's not recognised in the pci slot and I'm getting a bad reading from a mosfet. Took the mosfet off and still get the bad reading on just the pad so I'm assuming its the driver for that mosfet thats gone bad but finding one is impossible!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Originally posted by quiggy
        ... I'm getting a bad reading from a mosfet. Took the mosfet off and still get the bad reading on just the pad so I'm assuming its the driver for that mosfet thats gone bad
        Did you conclude you have a "bad" reading because the MOSFET was showing low resistance from Drain to Source? Or Drain to ground? If so, that is actually normal for certain video card MOSFETs. Reason being the GPU V_core rail usually has a very low resistance to ground - typically 1 to 5 Ohms. Most multimeters will indicate this as a "short-circuit" and make you conclude the MOSFET is bad when in fact it isn't.
        So depending on where that MOSFET is located, that may or may not be a normal reading.
        Also, a bad MOSFET - be it on the low-side or the high-side of a buck regulator circuit - will typically cause the PSU to crowbar / shut down. The fact that you can start the whole PC without the PSU shutting down means there probably aren't any bad MOSFETs.
        To avoid false readings when checking MOSFETs, I only measure resistance to ground and/or to Drain on the MOSFET's Gate. If the resistance is several kOhms or higher, it's probably OK.
        • R_J
          • 9623
          That seems to be a Richtek RT9611AGQW Synchronous Rectified Buck MOSFET Driver
          02= : Product Code
          3B52D YMDNN: Date Code
          • quiggy
            • Aug 2014
            • 136
            • United Kingdom
            Bad reading from drain to ground. But, if I change the mosfet, all readings are fine until I try power it up.
            I'll power up the card, my pci post card will give an unrecognised pci-e device code and it won't boot. When I remove the card again and test the new mosfet which was showing as fine prior to powering it up, the mosfet shows as bad again.
            I can only conclude that it has to be driver related which is what lead me to those.
            Am I right in assuming that provided the replacement driver has 02= printed on it, then it will be the same?
            • R_J
              • 9623
              02= should be the RT9611AGQW Did the fets short from drain/source to the gate? if they did check if there are low Ω resistors between the drive ic and the fet's gates. If there are no resistors or they are ok, the ic is likely bad.
              Check the pdf file and maybe you can check the ic's output resistance to confirm the ic's output is shorted etc.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • Loki_Fido
                Requesting help identifying chip in Macbook Pro A2485
                by Loki_Fido
                Hi ya folks,
                I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
                It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
                I replaced it and the SSD are fine. No more shorts.
                But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
                But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
                Chip marking...
                08-07-2025, 10:17 PM
              • skdsp
                Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
                by skdsp
                I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
                Attached is the photo.
                Thank you!
                09-27-2025, 09:05 PM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
