Solder paste questions ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Members,
    I have a SMD solder paste and it's getting harder,
    what should I do to make it softer ?
    Any liquid that I can mix with ?
    • 31258
    Re: Solder paste questions ?
    i think the base is rosin and IPA, so a drop - and only a drop, of IPA maybe.
    • bianchi77
      • Jun 2016
      • 1121
      do you mean my IPA for cleaning will softening this solder paste ?
      谢谢
        • 31258
        pure ipa should soften the flux, that's what it is - flux with ground up solder in it.
        • dicky96
          Solder paste recommendations please
          by dicky96
          Hi guys. Well I thought solder paste was just solder paste but apparently not
          I watched this short video
          https://www.youtube.com/watch?v=uSb1fgCMUug
          I want to try solder paste for resoldering BGA chips and LGA sockets as I am having no luck at the moment. I have no problem safely removing the old part, it's getting the replacement one to solder which is where I am going wrong. The Type 5 solder paste link he gives in the above video says it is not available.
          I want to use the paste like in the video on this thread
          https://www....
          05-11-2020, 03:31 AM
        • menshawy
          Question about solder paste vs solder balls
          by menshawy
          hi friends
          what about using solder paste to reflow vram because it is easier than solder balls
          but it will working perfectly or it will die after short time ?
          I need your experience
          thanks
          12-04-2021, 07:49 AM
        • Veyron7887
          Laptop overheating after replacement thermal paste
          by Veyron7887
          Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
          11-24-2024, 05:08 AM
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
        • Tarot Superstars
          What LED's to Buy To Replace Backlight LED's and What Solder with LED's
          by Tarot Superstars
          Hello.
          I changed the led strips on my Hitachi 32 inch.
          The TV is now ok since I have already replaced any capacitors that needed replacing.
          I have also bought a spare set of LED strips for the tv also.
          I want to be able to replace singular LED's in the LED strips if I need to, but I am not sure what value LED package to buy from Ebay in the UK.
          The LED strips I bought were:
          Replacement Backlight Array LED Strip Bar For Hitachi 32HB6J61U 32HBT41U 32" TV
          On ebay I have a choice of singular LED's with voltage and...
          09-02-2023, 02:44 PM
