Thermal cut-off sensor/fuse
  • evilkitty
    • Nov 2017
    • 299
    I got this unit free cause it did not work, was claimed to be DOA and past it's return window on the way to the dumpster
    The issue seems to be this part:
    https://canada.newark.com/thermodisc...50v/dp/67C6643
    i guess this blows at >10A or overheats at 117C
    given this part is bad either it was defective or blew on 1st use (power surge?)
    when bypassing it the unit pulls 12.7A (clamp on meter)
    maybe it was a bad combination of tolerances?
    Perhaps i should replace it with this?
    https://www.newark.com/nte-electroni...77v/dp/29C4799
    or should i replace it with the original part
    • 31277
    Re: Thermal cut-off sensor/fuse
    use a part that can handle atleast 15A, maybe 20 - or your asking for trouble!
    btw, i hope you know you shouldnt solder those - try to use crimp-sleeves if you can.
    i'v seen them trip while being soldered!
      • Jul 2011
      • 6070
      The 15 amp should be alright I would not go higher than that
      You can only crimp these thermo fuses
      Or
      You can solder them however you need to put a wet rag on fuse part of it to keep the heat off of it will make it hard to solder
      • petehall347
        • Jan 2015
        • 4448
        hemostats
