Unknown Surface Mount Component
+ More Options
Posts
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I need to figure out what this is ... I've tried googling the identifier as I see it, but no love ... anyone know what this is?
    sigpic
    • 30978
    Re: Unknown Surface Mount Component
    so what is it part of?
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Bright single LED 4.5v flashlight.
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Here is the whole circuit:
        sigpic
          • 30978
          it's a chip - custom.
          did you remove some resistors?
          those chips only handle 1.4A, the board usually has some parallel resistors to limit the led current.
          if your trying to fix it, you can bypass it for 100% or off - no multi-mode.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I have not removed anything from that circuit board ... thats all that was on there, those two components. I assume the little box is a resistor.
            What do you mean by "100% or off - no multi-mode"?
            sigpic
              Multi-Mode: Low beam, Medium beam, High beam, Strobe, and SOS modes.
              Or it has just ON and OFF.
              • redwire
                • 3906
                It appears to be flashlight LED controller + MCU. Some IC's have linear constant-current control and others have buck converter to do that for higher efficiency.
                My guess is YX8133A by shiningic but hell to translate. Replaced by YX8231B or YX8232B. I can't find much for SMD marking codes.
                If you have an inductor stashed away somewhere, it is a buck-converter type.
                  • 30978
                  a better question, is what is the pcb diameter and how badly do you want to fix it?
                  there are better boards on ali-express.
                  do you know the led type? Q5? T6?
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Oh - yeah ... it has High, Low, and Strobe, but I'd be ecstatic if I could make it just do HIGH and OFF.
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      The diameter of the PCB is exactly 20mm ... and I looked on the LED for ANY identifying markings, and I found none .... HOWEVER ... when I connect a 4.2 volt 18650 battery directly to the LED (no current limiting resistor at all), it lights up like an angel from heaven just popped in the room ... and it draws 1.5 amps which I feel is WAY TOO HOT to run that led ... but at least we know what it CAN do although it got hot so fast, I think it might burn out at that kind of continuous draw ... when I put a CC power supply on it at no more than 4.5 volts at 250ma its nice and bright..... if that tells you anything ...
                      sigpic
                        https://www.ledgroupbuy.com/cree-model-comparison/
                        When you bought that flash light, what does the seller say/claim?
                          • 30978
                          well a Q5 is 350mA and a T6 is 700mA - assuming your not overdriving them.
                          if it has zoom or you have a magnifier,
                          a Q5 has 3 rectangular segments and a T6 has 6.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            So the LED looks exactly like these ...
                            sigpic
                              • 30978
                              seriously?
                              that's rare.
                              well they could be anything - .5w, 1w, or 3w
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                seriously?
                                that's rare.
                                It took a fully charged 18650 like a champ and managed to source 1.4 amps from it ... damn near burning my skin before it ever fried, so it's a pretty decent LED ... What I really want to do with this thing is power it from a couple of 18650's at a respectable brightness - maybe 200ma .... with just an on / off feature, no blinking or any of that fancy stuff. I might just stick with the LMN317 constant current config ... seems to be reliable although maybe a little too lossy ...
                                sigpic
                                  • 30978
                                  then you need one of these:
                                  they are made for this job, if you want more current you just put 2 or more in parallel.
                                  you get a strip of 10 for under $2 on aliexpress.
                                    3.6V Voltage source feeding LM317 CC circuit to drive White LED (Vf of 3V @200aM) is not going to work because 317 has internal 1.25Vref, you will need more than 3.6V Voltage source.
                                    Build it and take some data.
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      Thats why I was thinking of using TWO 18650's in series ... but what really bothers me about the LM317 option is all the waste ... id be recharging batteries too often ...
                                      STJ suggested the AMC7135 ... it looks pretty tight ...
                                      sigpic
                                        Page 4 of the AMC7135 spec sheet has the Pd calculation.
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 08:10 PM
                                          Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
