ALL ELECTRONICS LI-ION POLYMER BATTERY PACK, 3.7V 25AH good buy
    • Jul 2011
    • 6057
    All Electronics has these Li-ion polymer battery pack, 3.7v 25ah for $75.00 at first when I first saw them but now they are $55.00
    https://www.allelectronics.com/item/...7v-25ah/1.html
    I thought I would give them a try and see if they are really 5000 milliamperes per battery
    So I took the battery pack apart and the results are really 5000 milliamperes and that what it says on the battery
    This battery pack is very easy to take apart but just be careful when doing this
    I thought I would share this with you people on this forum
  • brethin
    • Dec 2008
    • 1907
    Re: ALL ELECTRONICS LI-ION POLYMER BATTERY PACK, 3.7V 25AH good buy
    pics of it apart and the battery's inside?
      • Jul 2011
      • 6057
      Here are the pictures that were asked about
        Spec sheet for PL-896474-2C.
        https://cdn.badcaps-static.com/pdfs/...e8154cdb91.pdf
          • Jul 2011
          • 6057
          Originally posted by budm
          Thanks for sharing this data sheet with us the last part of the data sheet has some very important information about soldering the tabs or if you spot weld the tabs
          • brispuss
            Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
            by brispuss
            Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
            Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
            I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
            12-28-2022, 02:58 AM
          • razenxd
            How can I charge that battery pack?
            by razenxd
            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
            Now, I have noticed a few things.
            The "dead" battery, while connected to charger and NOT Charging will...
            12-05-2024, 06:11 AM
            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
            by sam_sam_sam
            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
            So I have put them on the battery testing machine to drain each battery cell down to...
            09-04-2022, 04:45 PM
            Bauer tool battery pack charging with a HERCULES charger modification
            by sam_sam_sam
            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
            05-06-2023, 12:17 PM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
