Hi all does anyone know what is the max voltage a twin uk plug socket will take,can you, for example, have six-way adaptor in one socket and another or smaller in the other,running just tings like dvd,tv,set top boxes and so like.
Standard UK sockets
Re: Standard UK sockets
voltage is 230-250v,
your talking amperage.
the maximum current per socket is 13A continuous - although i have seen some cheap ones melt if you do that!!!
it really does not matter how many things you connect as long as the amps dont total over 13.
and just for fun:
https://www.youtube.com/watch?v=K7DOh_dT740
Multi-socket adapters are pretty much essential in HiFi, TV cabinets and on electronics workbenches but you have to be mindful of the kind of appliances you plug in. stj is right to warn about the danger of drawing close to the 13A limit. The construction standards of typical multi-socket adapters tend to be nowhere near as good as those found in the kind of outlets built into houses.
I like to fit the mains plug of a multi-socket adaptor with a 5A fuse just to make sure it doesn't accidentally get overloaded. Four lots of up to 300Watts can still be supplied which should be plenty. If appliances individually draw significantly more (e.g. kettles, toasters clothes Irons etc.) then do everything you can to plug them directly into a wall outlet.
I have a pair of frankly insane 12-way socket panels on the wall above my workbench but they're typically full of little phone chargers and the like. I doubt they ever see more than a couple of Amps pass through.Comment
on one 6 way i have
dvd player
virgin box
usb hub
amazon box
hdmi splitter
xbox
that is plugged into one of the twin wall sockets
the other socket just powers the tv but wanted to plug in either 4 or 6 way for other things ps4 and like
can i do this ?Comment
technically so long as you dont switch everything on at the same and max running power of everything added up is no more than 13 amps it should be fine .. when powering things up start with highest current one first then next lower one etc etc .Comment
Most of the cheapo Poundland stuff just uses a few aluminium strips for the conductors... and they're really thin!!!voltage is 230-250v,
and just for fun:
and the fake poundland fuses .. the led solar floodlights are good though for the priceComment
This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...09-06-2024, 08:30 AM
by actwonHello Everyone,
If this is the wrong section, please move it to where it belongs. I have an automotive ECM that has PLCC32 sockets. One of the sockets are bad so I am trying to remove it. However, when. heat the area a lot of brown residue (what looks like overheated rosin core flux). I have spent a lot of time trying to clean the area, but I can't get it removed and I am not able to remove the socket. I don't want to use excessive heat. I don't want to burn the PCB where he socket resides. I have used q-tips soaked in 99% IPA. Does anyone have tips for me? I'm using soldering irons... -
by F-18Hello Newbie here..., few years ago i bought a broken twin frozr gtx 750, seller said that theres heavy stutter issues in every game tested. i inspect it a little and find two tiny capacitor torn out near the pcie x16 gold pins, i assume it will be running in 8x ? the furmark-like gpuz test showed that there's indeed a heavy stutter and low fps but i tried this with EXP GDC and a laptop.
Few months ago i bought a broken Twin frozr gtx 750ti with unknown issues, i didnt test it and jump straight to thinking that i probably need to solder everything that the gtx 750ti have but gtx 750 didn't...11-07-2025, 11:12 AM -
This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 08:50 AM
by Simonc123Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...4 Photos-
- Loading...
