MSI twin frozr GTX 750 not shown in device manager
  • F-18
    • Sep 2024
    • Indonesia
    Hello Newbie here..., few years ago i bought a broken twin frozr gtx 750, seller said that theres heavy stutter issues in every game tested. i inspect it a little and find two tiny capacitor torn out near the pcie x16 gold pins, i assume it will be running in 8x ? the furmark-like gpuz test showed that there's indeed a heavy stutter and low fps but i tried this with EXP GDC and a laptop.
    Few months ago i bought a broken Twin frozr gtx 750ti with unknown issues, i didnt test it and jump straight to thinking that i probably need to solder everything that the gtx 750ti have but gtx 750 didn't have.
    What i solder (as far as i know) : 4th phase inductor (L15) , mosfet (U4539), and electrolytic capacitor (C143) with their capacitor/resistor pairing. Also a mosfet in the back of the card (U508).
    So i add everything and it worked out for a moment. The gpuz test and heavens benchmark runs well. (I still only have exp gdc and laptop to test the gpu at this moment)
    After a while the gpu came back with its former issues (heavy stutter in gpuz test and heavens) again but with an added issues, now that i have an old pc to test it with, the gpu won't show in device manager. But with the exp gdc still detect the gpu but with an error 43 code, i used a fix patch and installed a error 43 fixer patch for EXP GDC i find on the internet but the error 43 problem persist.
    i found a youtube videos about gpu troubleshooting and with MSI v310_20 schematics, i measured what i could using multimeter with result below.
    Continuity measurement :
    - first 3 gold pins(12v input), no beep
    - 8th gold pin from the left (3,3v input), no beep
    Resistance measurement :
    - 1st, 2nd, 3rd, 4th inductor phase, 39.0 ohm
    -VCC_NV_PWM, 186,4 ohm
    -PEX_vdd, 57 ohm
    -5v rail (U5), 178 ohm
    -3v3 PEX (U502), 390 ohm
    -12v PEX (C72) 540 ohm
    Some random Voltage measurement at the back of the card :
    1.05V, 1.8V, and 13V
    bios chip is at 3,6V
    vcc nv pwm shows 5 volt
    gpu die isn't getting hot, not even warm, just very slightly warm.
    voltage not stable, sometimes appear and then vanish.
    I will post the picture of what i soldered from gtx 750ti into gtx 750 later.
