What is an M8348 IC?
  • lax luthier
    • Mar 2018
    • 19
    Hello. I havee been examining a small test tool formerly owned by the Late Great audio designer James Bongiorno. It has a single 8 pin dip which is almost certainly some type of opamp.
    However I've had little luck finding useful info about it online.
    The only other lettering on it is 4250C/
    Thanks in advance for any help with this, lax
    Why don't you mine your own Bismuth,
    Mine your own Bismuth
    So you won't be mining mine?
    Re: What is an M8348 IC?
    Pictures of what we are dealing with?
    https://cdn.badcaps-static.com/pdfs/...571d111124.pdf
    • lax luthier
      • Mar 2018
      • 19
      Thanks, budm. So it is an LM4250.
      A photo would just show a small circuit board with an 8 pin DIP package and a handful of caps and resistors. Now I have a path to follow, thanks again, lax
      • paulyboy
        Help with IC identification it's lettering is CW0Q
        by paulyboy
        My microscope is not getting power and upon opening I have found an Ic that's burnt it's lettering is CW0Q and it has 6 pins looks to be sot23-6 package.
        Ps will upload Pic shortly
        06-02-2024, 02:54 AM
      • Kush679
        MacBook Pro M1 Activate Mac
        by Kush679
        Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
        Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
        06-20-2025, 09:43 AM
      • Bogeski
        Samsung 32" T-con problem
        by Bogeski
        Hello to all, I'm new here on this forum, so I have T-con board that makes me crazy, so when I start to diagnose the problem, on first MAX9591 was overheating so I tried with 1 flat cable from panel and half picture was working and IC was fine, so I take out T-Con I check every capacitor, diode, mosfet, everything was good, so I continue to right board from the panel, I check everything, and I didn't find any issues, so I connected again, I started the Tv with both flats, and TV worked, I tried every settings in menu and was working fine for more than 30min, so I turned off , I take Out again...
        05-25-2024, 12:55 AM
      • Sparky74
        by Sparky74
        Former IT network analyst and web designer-developer. Currently qualified electrician. DIYer tinkerer of all things electronic
        01-08-2024, 10:03 AM
      • TecnicaNTT
        Component Identification Huawei Matebook D 15
        by TecnicaNTT
        Need to identify a component that is broken.
        One I already identified using the forum but the other on the left is missing.
        I cannot give any lettering advise because the component is broken.
        Any help would be very useful.
        Motherboard model is: DAH98AMBAD0
        Latpop: Huawei Matebook D 15 Boh-WAQ9R...
        05-03-2023, 10:17 AM
