how to automate relay testing
  • redwire
    • Dec 2010
    • 3912
    Re: how to automate relay testing
    Sometimes I have to troubleshoot relay failures when in the field. This is for heaters, furnaces, stoves, refrigerator control boards.
    Ideally it should be a board-level swap, but it's easier to carry around a box of assorted relays and do a primitive test... tapping them... whack... and use a 12V car light bulb like #1156 and separate DC power supply to pull in the coil.
    Ageing relay contacts have increasing resistance and will melt the case or burn the PCB if higher current (>10A) is flowing. Dishwasher fires/recalls caused by this.
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
    • jm1234
      9V relay temperature 40C
      by jm1234
      Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
      I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
      05-09-2024, 03:03 AM
    • edugimeno
      Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
      by edugimeno
      Hi everyone!
      I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
      I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
      This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
      To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
      I respected the polarity, positive to cathode of protecting diode
      So provided all...
      04-18-2024, 01:15 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
