Burned resistor, what value ?
  • diif
    • Feb 2014
    • 6978
    • England
    I open my friends dead fan and find a burned resistor.
    Looks like black black ? Gold
    The burned band I think is either grey or black, so to me that suggests 0 ohms. Was it used as a fuse ?
    Thoughts please ?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Burned resistor, what value ?
    Maybe brown black silver gold, but this resistance is a bit low as a guess as to what the original resistance would be.
    This looks like a capacitive dropper power supply, so yes it was mostly used as a fuse.
    What's the uF of the yellow capacitor, and what is this controlling (cant be the actual fan motor? Relay somewhere? How big of a relay?)
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Looks like a 1ohm 2Watt resistor
      • diif
        • Feb 2014
        • 6978
        • England
        Thanks eccerr0r. The yellow capacitor top left is 0.1uf, the larger one bottom middle is 0.33uf both X2
        The connector top right has three wires that go into the fan, I doubt the relay is inside. It's 230V 21-33W.
        The IC is an Atmel Mega48pa.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yes I would also think it should be in the ohms range (gold multiplier band) and not tenths of ohms range (silver multiplier band) because of the capacitive dropper circuit. The third band looks silver-ish.
          The "bottom middle" I think what you mean / 0.33uF capacitor is what I was curious about - this is the dropper capacitor. A 0.1Ξ© resistor might make sense with a 1uF dropper but agree with Andrew that it should be higher than this, mainly due to it being pointless being that low for a 0.33uF.
          • diif
            • Feb 2014
            • 6978
            • England
            Thanks, I've stuck in a 0.33 ohm 2watt resistor as it's the closest I have in stock.
            Fan now powers on.
            I think I have discovered the reason it burnt. He had connected it to one of those cheap dimmer plugs https://www.amazon.co.uk/Dimmer-Adju.../dp/B01G1WEKW4 and turned it down for the first time yesterday.
            Looking at the fan instructions, that's not how it wants controlling.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Good work!!!.....
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • MidnightRoller
                Can a resistor lose resistance after hot air?
                by MidnightRoller
                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                02-02-2022, 11:46 PM
              • artvandalai
                What resistor ohm will work better to repair this waterpik?
                by artvandalai
                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                01-05-2025, 04:10 PM
              • chth96
                Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                by chth96
                I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                Since then, This AC/DC adaptor have been out of order.
                But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                And Is there any possibility that it will suddenly explode as well as to be out...
                12-03-2023, 04:40 AM
