Burned resistor, what value ?
  • diif
    • Feb 2014
    • 6978
    • England
    I open my friends dead fan and find a burned resistor.
    Looks like black black ? Gold
    The burned band I think is either grey or black, so to me that suggests 0 ohms. Was it used as a fuse ?
    Thoughts please ?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Burned resistor, what value ?
    Maybe brown black silver gold, but this resistance is a bit low as a guess as to what the original resistance would be.
    This looks like a capacitive dropper power supply, so yes it was mostly used as a fuse.
    What's the uF of the yellow capacitor, and what is this controlling (cant be the actual fan motor? Relay somewhere? How big of a relay?)
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Looks like a 1ohm 2Watt resistor
      • diif
        • Feb 2014
        • 6978
        • England
        Thanks eccerr0r. The yellow capacitor top left is 0.1uf, the larger one bottom middle is 0.33uf both X2
        The connector top right has three wires that go into the fan, I doubt the relay is inside. It's 230V 21-33W.
        The IC is an Atmel Mega48pa.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yes I would also think it should be in the ohms range (gold multiplier band) and not tenths of ohms range (silver multiplier band) because of the capacitive dropper circuit. The third band looks silver-ish.
          The "bottom middle" I think what you mean / 0.33uF capacitor is what I was curious about - this is the dropper capacitor. A 0.1Ω resistor might make sense with a 1uF dropper but agree with Andrew that it should be higher than this, mainly due to it being pointless being that low for a 0.33uF.
          • diif
            • Feb 2014
            • 6978
            • England
            Thanks, I've stuck in a 0.33 ohm 2watt resistor as it's the closest I have in stock.
            Fan now powers on.
            I think I have discovered the reason it burnt. He had connected it to one of those cheap dimmer plugs https://www.amazon.co.uk/Dimmer-Adju.../dp/B01G1WEKW4 and turned it down for the first time yesterday.
            Looking at the fan instructions, that's not how it wants controlling.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Good work!!!.....
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                09-12-2024, 02:00 PM
                MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 01:58 PM
                Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-07-2024, 05:00 AM
