Ikea branded TV? Obscure fault.
  • Trevtron
    • Apr 2015
    • 124
    • Portugal
    For years Ikea have had dummy TV sets adorning their living room furniture displays, but I discovered the other day that they actually sell their own brand TV's - at least they do in their Seville branch.
    It's model number is 602.566.01. I fully expected it to be Vestel crap, but the menu structure didn't feel Vestel-ish, and the sound quality is better than I would have expected from them too.
    Unfortunately it wasn't all good news. This particular set belongs to a German customer who bought the set last year because it has a built-in satellite tuner. Perfect for receiving the myriad German channels available on Astra 1. And it performed this task perfectly well, except for the fact that re-ordering the channel list into a sensible order is right royal PITA.
    But my task was to add some English TV channels as he is going to rent out the property in the summer. This is something I am used to doing; a 90cm dish receives a handful of UK channels from Astra 2 and, with an offset LNB, the Astra 1 channels can be switched in via a DiSEqC switch. And this is where it went all pear-shaped. As soon as the DiSEqC switch was introduced, most (not all- could still get RTL) of the Astra 1 channels showed 'No Signal'. I tried swapping ports, 3 different DiSEqC switches, different LNB's but each time with the same result. Bypassing the DiSEqC switch restored normal operation on either satellite. Eventually in desperation (and to prove I wasn't going mad) I tried an external satellite receiver and it worked perfectly first time. Whew!! It wasn't me. It appears the TV is somehow interfering with the DiSEqC switch causing loss of signal.
    Now I don't expect anyone on here to have come across this fault - it's a fairly uncommon scenario, but of course I am open to suggestions. The owner really wants to use the TV's internal sat tuner - it's why he chose that set - and of course it cuts down on remote clutter, complications for guests etc. etc. What I would like to know is who made the set, and if anyone has had any luck getting tech. help from Ikea.
    I am hoping to prevent a complicated outcome; so far I've only been paid 50% of my bill for installing the dish etc. The customer understandably wants to see his system working, but what can I do if it's his TV that's causing the issues?
    • 31278
    Re: Ikea branded TV? Obscure fault.
    not enough current to drive both LNB's
    most diseq switches dont alternate the power, only the RF.
    this keeps the LNB's stable for a fast lock when channel hopping.
    look at the area near the tuner, find the lnb voltage control and look at the caps.
    btw, on big switches that feed 4 or more recievers you often use a seperate psu because of this.
    • Trevtron
      • Apr 2015
      • 124
      • Portugal
      Well done @stj, I reckon you have hit the nail on the head there, thank you!
      I will try disconnecting the 'other' LNB just to confirm, but this makes perfect sense. Actually it a kind of a D'oh! moment for me. Here's hoping it's not raining on Monday.
      Opening up the TV is not a preferred option at this stage, it's neatly recessed into the wall (probably thus creating a cap-killing "oven") and will be a real bitch to remove. Guests are arriving in a few days so hopefully a temp. fix will do for now.
      I've had LNB voltage issues before (no H) with a long cable run and through that I identified an LNB with a particularly low (80mA) current draw. Hopefully I'll still have a couple of those in the shed.
        • 31278
        some recievers actually have a current limit and a sense circuit to detect cable shorts and protect the drive circuit too.
        • Trevtron
          • Apr 2015
          • 124
          • Portugal
          Yes, I'm sure all modern receivers do. Some self-recover when the short is lifted, others (Technomate TM5402 for instance) need a re-boot to clear the error condition.
          Back to the original topic- I took along a 4-way DiSEqC switch, figuring no receiver could be expected to power up 4 LNB's simultaneously. I checked it with a cable-checker and sure enough it only powers up the selected port. Just to be sure I also changed the LNB's for 'Best' branded ones which I know from a previous long-cable issue draw less current (80mA on V) than most, and bingo! Both sat's scanned in and working fine side-by-side. Unfortunately the owner was breathing down my neck (and offering me beer at 10am!!) so I didn't get the chance to check the 2-way DiSEqC before removing it. But I kept it and will definitely check it at some point.
          Thanks again for your suggestion stj.
          • keldeo
            Obscure Pentium laptop, sudden short?
            by keldeo
            I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
            At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
            01-02-2025, 03:22 AM
          • fitz301
            Looking for a seemingly obscure schematic written on unobtainium parchment... Soundesign 5595
            by fitz301
            I'm really hoping somebody on this forum, who have way more expertise than I, can help me with something.
            I am searching for the schematic to hopefully repair my 83 yr old mother's console stereo system, it's a 1979 Soundesign 5595 w/ turntable, AM/FM stereo receiver, cassette and 8-track tape, everything works but there's a loud bass hum when using the cassette player and the FM radio needs to be turned up to full volume to hear it, every other part seems to work like it should with the exception of burnt out dial lights and needing new belts.
            I've been...
            10-19-2025, 06:16 PM
          • Dan81
            The Cheap Duo - Two SiS machines
            by Dan81
            Just as the title states. Two cheap SiS machines, surprisingly stable.
            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
            CPU - P3 1100MHz Coppermine...
            04-16-2022, 12:28 PM
          • ngth82
            SILO branded tv - model SL-4013 - no image, Nonbacklight, doesn’t always turn on
            by ngth82
            Has anyone ever worked on a “Silo” branded tv?
            I have one. Model SL-4013. The tv is in great physical shape.
            The tv only comes on very now and then. The backlights are good - I dismantled the tv and checked out the strings.
            The backlight circuit comes up to ~35V when it’s not working. It goes up to 75V to illuminate the strings when it works.
            The big cap stays at 165V in a working and broken state.
            The tv doesn’t always turn on either with the remote or the power button. The tv’s red standby LED...
            04-21-2020, 05:36 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
