Can anyone tell me why turning down the idle of a 1100 watt Ryobi 4 stroke petrol generator would allow a washing machines water pump to start working again.
The long story. I live off grid and at times use the generator for a LG direct drive washing machine.
I turned up my generator's idle expecting to increase the voltage output from 230 volts closer to the 240 volts that is recommended in Australia for electrical goods.
Some days later my wife noticed the washing machine still washing, was no longer pumping water, but would still spin if the drain hose was lowered to the ground. So I pulled out the pump, checked for blockage, wired it out off the machine, but it only spun sporadically.
I bought another generic 40 watt pump on eBay. Wired it in the machine and still nothing. Tried external pipes of water, wired it up separate from the machine and still nothing.
One last attempt was to turn the revs back down a bit and it worked.
Original pump is rated at 30 watts and works fine.
