Looking for a blow/butane torch to be used for heat shrink tubing
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    Up until now I have been using lighter to shrink my tubes While it works, it can get problematic at times. I am looking for a hand held butane blow torch that will get the job done.
    I have went on amazon and bought a "cooking" torch. Well, that thing will burn the connector, wire, my hair along with the heat shrink. Flame is way too strong and big.
    I am looking for a self igniting hand held torch with small flame. Also, it would be nice if the trigger would release the butane and ignite it at the same time. The one I have, I have to turn up the gas first with one knob and then ignite it with the trigger. Then close the gas valve when done as it does not shut off by itself.
    If you have have/used on that would fit the bill, can you link to it?
    Thanks.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Looking for a blow/butane torch to be used for heat shrink tubing
    I think that will make the work too hot and may even burn. The heat from my soldering iron work perfect for me. However, it's your choice, still.
    • NTkiller7000
      • Dec 2015
      • 44
      I have a $5 butane blow torch I found at Walmart of all places. Found mine in the checkout line. Works great for heatshrink tubes! have a look https://www.walmart.com/ip/Eagle-Jet...hter/213634655
      Just trying to make these stupid electrons behave!
      ...Not having too much success, they keep flying around those atom thingy-majiggers...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8696
        The blue torch-like flame is an indication of an extremely hot flame. What is making you desire a torch flame? The natural gas flame is equally extremely hot.
        Same here I'd rather just use a solder iron or hot air - either a hot air gun or a SMD rework station wand.
        • R_J
          • Jun 2012
          • 9535
          I have used a Weller PSI100K and the Ultratorch UT-100 I think most portable butane solder iron/heat tools have a hot air attachment
          or search "butane heat tool" lots to choose from
          • diif
            • Feb 2014
            • 6978
            • England
            I have a SolderPro by Iroda. It has a hot air attachment that is perfect for heatshrink.
            • petehall347
              • Jan 2015
              • 4426
              hot air is best but other methods can and do work satisfactorily . am sure i have used a hair dryer in the past .
              • diif
                • Feb 2014
                • 6978
                • England
                Forgot the link https://www.amazon.com/Iroda-SOLDERP...roda+solderpro
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  +1
                  I use my Leister because it lets me tweek the temperature and air flow rate. I can also choose a nozzle that will direct the air/heat to a very specific place -- helpful when heatshrinking wires that are IN a harness and you don't want to toast everything around it!
                  Or, a suitably sized tip on a soldering iron (with a bit more patience)
                  If you're doing individual shrinks "in open air", then you can get a heat gun (I think HF has some cheap ones at $10 and you never have to worry about running out of butane/propane) or even a hair dryer.
                  [These last two tend to put out way too much air and heat so not good if you're patching something with other stuff around it]
                  I'd be leary about any sort of open flame as its just too easy to fry something (e.g., plastic parts, insulation) before you realize the heat has drifted off target!
                  • gabik111
                    ORD spotter
                    • 142
                    • USA / Poland
                    That's what I am using and works for me for years. It's god when you using it not too close.
                    Laptops and computers repair.
                    • NTkiller7000
                      • Dec 2015
                      • 44
                      Originally posted by gabik111
                      That's what I am using and works for me for years. It's good when you using it not too close.
                      Yep, works great. Turn the gas all the way down, hold an inch and a half away from target, and heat away. If your're careful, you can even desolder with it. I've used it to pull components off a dead single layer board for another project, just don't focus the heat in one place for too long.
                      • socketa
                        Bestec ATX0300F5WA - fast,or slow blow, fuse?
                        by socketa
                        I bought a dead motherboard, and connected it to this PSU,
                        Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                        So now i truly got a bang for my bucks, and something else to try and fix.
                        The fuse was blowen, and the top was blowen off of a TNY276PN chip
                        The glass fuse didn't have any marking to say if it was fast or slow blow
                        So i checked the marking on the PCB thinking that that would tell me,
                        but it 's got a T/F8A printed on the board
                        So should i get a fast blow fuse, or should...
                        05-17-2022, 01:22 AM
                      • Widget
                        Small Eiger LED Torch
                        by Widget
                        Hopefully this falls under "weird devices".
                        I have a small torch, nothing special. I tried using it today, but it turned off after a few seconds. This happened a few times. Then the LED inside started to get dim and flicker, then it would go off, then it would come on bright, then off, then on dim and flicker etc... if you get my drift. The battery is a AA 1.5v which works fine.
                        Now, it won't come on, so thought I'd tear it down and have a tinker. I'm still a novice, so don't really know what I'm doing. I thought I'd try the LED to see if it works (which...
                        07-22-2023, 09:30 AM
                      • ohren
                        Why did my MOSFET blow up?
                        by ohren
                        I had a switching transistor and PWM IC blow up as part of a repair, where a big chunk of each went missing. Now I would like to understand the likely turn of events, and maybe determine if I did something stupid. If nothing else, I should at least extract some lessons from it.
                        "IC10" can be found on page 169 in the service manual:
                        https://www.manualslib.com/download/...n-Mas-101.html
                        The entirety of the repair is basically:
                        1. Device doesn't power on (IC10 supply voltage unstable)
                        2. Replaced C18 and C66
                        3. Device works...
                        04-30-2023, 06:59 AM
                      • mossieurclo
                        Marantz PM7200 Can't adjust Bias or DC Offset
                        by mossieurclo
                        Thanks for reading me:
                        After i repaired the speaker protection board of that amplifier, all was ok.
                        So I then proceeded to adjust iddle current, got it, then DC offset. Oh, bboy.
                        At that stage, on the left channel, after first seeing normal readings while moving the trimpot to get to the correct setting, suddenly readings were all over the place and did not respond to my turning the trimpot.
                        I played music to earphones, to find that there was no sound on left channel. Only distorted crackles on peaks.
                        I took out the board...
                        09-30-2020, 08:11 PM
                      • mitsu2k
                        The Real Dangers of conductive glue.
                        by mitsu2k
                        I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                        Here is an experience I...
                        04-16-2023, 06:29 PM
