TL431 question
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    TL431 question
    Good day folks. I'm having a bit of a puzzle trying to figure out something. I saw this video where the guy explains how you can test TL431's but sadly doesn't explain the principle of operation.
    He connects the GND of the PSU to the ANODE, then the REF and CATHODE via a 1k resistor to 5v. He measures the voltage after the diode and gets 2.5v. I know 2.5 if the reference of a TL431, so it can't be an arbitrary number. How does the math work here ? I know a 431 is an adjustable zener - that I get, but I can't work out the numbers here.
    I looked up the datasheet and had a look at the internal diagram: it's basically an op amp driving a NPN transistor. The REF goes to the non inverting input and there's a 2.5 Vref on the inverting input. So the chap in the video sends 5v into the non-inverting input, but what happens to that 2.5Vref then ?
    Sorry for this being a stupid question, since it's a standard building block components, but that's precisely why I want to learn about it more, plus his test seems fairly efficient and bulletproof. Cheers.
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: TL431 question
    Actually I got it now, since there really isn't any math involved. It was the principle of operation that confused me, but I got it: when REF connects straight to the positive rail, the transistor becomes fully conductive, allowing full current to flow through, thus bringing down the voltage at the cathode to 2.5v (since at that point the non-inverting input takes over and stops the transistor, since both inputs are equal), which is what the chap demonstrates shows. The value of the resistor doesn't influence this - it's just to prevent overcurrent through the 431's transistor. I think that's it.
    Wattevah...
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      Re: TL431 question
      A couple of tips if you experiment with TL431s and TL430s.
      Pay attention to the minimum "zener" current. If the current is too low the TL431 will oscillate. I've seen this with other shunt references, too.
      If you connect the REF pin to a voltage that can vary the TL431 can be used like a comparator (with K being the "output"). But pay attention to the minimum and maximum output voltages in the spec sheet. IIRC, the "Low" can be as high as 2V; The "High" is probably a volt or a little more lower than the positive rail.
      It's a very versatile IC, one that was created in the 1970s and too good/cheap to be made obsolete.
      PeteS in CA
      • rievax_60
        • May 2012
        • 897
        • australia
        Re: TL431 question
        Also, the TL431 will draw an increasing current of up to about 500ua well before the Ref pin reaches 2.5v. The TL431 needs to be allowed to draw a minimum of 1ma before any driven circuitry responses.
        For example, if the TL431 is driving the LED in an opto coupler, a resistor of about 1K needs to be placed across the LED to achieve proper regulation.
        • redwire
          • 3902
          Re: TL431 question
          It behaves like a zener diode - but if you remember a TL431 has an op-amp stashed inside of it, that needs its own power ~0.5-1mA, then the IC is easier to understand.
          ATL431 is improved, low Iq version ~35uA that is stable with most load capacitances.
          • magneh
            Behringer Eurolive B205D repair - help identifying transistor
            by magneh
            Hello
            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
            Still, I need to replace this transistor....
            06-18-2025, 02:34 AM
          • elsomer
            help to identify transistor msi ms-15ck1
            by elsomer
            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
            02-17-2025, 05:30 PM
          • rddube
            Help with blowing transistor NAD T752 receiver
            by rddube
            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
            09-01-2022, 05:19 AM
          • amigo744
            xbox series x u82 5 pin transistor voltages ?
            by amigo744
            hello there,
            xbox series x hdmi u82 transistor 5 pin,
            can anybody tell me voltages of this transistor in standby and power on mode ???
            on which pin of this transistor are the voltages ?
            regards
            08-16-2023, 08:05 AM
            AO4601 AO4601L Transistor (Applications Laptops) Datasheet
            Complementary Enhancement Mode Field Effect Transistor
            The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
            11-05-2024, 08:21 AM
