Solid caps vs electrostatic caps (computer psu)
    Re: Solid caps vs electrostatic caps (computer psu)
    But aren't those 5V, 3.3 are minor rails low current not the 3.3V heavy current output?
    http://home.coolpc.com.tw/fb/FSP/HEX...XA-HA550-3.jpg
    So if I look at it correctly, the combined 3.3V and 5 output power is 100W so then what you will have left is 450W for the 12V?
    I can see pro and con in that design.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      It's basically a requirement for handling the low power states of Haswell CPU's and later. (C6 & C7).
      Group regulated PSU's can't handle such a load.
      Pretty much all modern ATX power supplies use DC-DC conversion for the 3.3v and 5v.
      Of course you need to "upsize" the 12v to compensate for it.
        Con: the power dissipation of the rectifier for that 12V will be pretty high.
        Do they implement the Synchronous Rectification some how to help reduce the power loss?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          AFAIK all ATX supplies with 80+ Platinum and higher rating have DC-DC designs for the minor rails.
          And they all also employ Synchronous Rectification, I think the Seasonic X series was first on the market with it in 2009.
          I honestly don't think it's possible to design a true 80+ Platinum PSU with full range input without it.
          So that speaks in favor that the efficiency loss is extremely minor.
          Remember that you can design a DC-DC module with very close to 100% efficiency.
          But the same can't be done with a AC>DC conversion (or wise versa)
          Also remember that while there is some loss in DC-DC conversion there is also loss in the coils required for a group regulated unit.
          • Stefan Payne
            • 1267
            Nope, there's one exception, Antec Earthwatts Platinum.
            Its even most 80plus Gold units have DC-DC, I only know of the FSP Aurum Plattform that isn't DC-DC...
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
              by momaka
              03-15-2023, 10:17 PM
              Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
              by momaka
              This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
              Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
              Macron Power Technology Co. LTD.
              Let’s look at the PSU itself.
              The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
              06-02-2021, 10:05 PM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
