Adding remote to RF central locking unit (project)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. The project is fairly simple: I need to implement a system to remotely switch on/off a light on my floor. The reason for this is because my neighbours don't want to install a brighter lightbulb to illuminate the hallway because, so they claim, it consumes more power, thus adding to the building's electricity bill, despite me trying to explain otherwise since it's a bloody LED bulb AND it's on a PIR sensor which means it's off 90% of the time. People have no idea how electronics work and even the concierge herself asked me to oblige and deal with the crappy 5w one they decided to install, which is so dim it's just ridiculous, it's like a candle, so much so I'm even having trouble getting my key into the keyhole without resorting to my phone's torch, not to mention it's a potential safety hazard when you exit the door early in the morning or at night and someone could be lurking in the dark...you get the point, so I figured it's time I did something something about it in such a way that nobody can complain about it, but at the same time only I would benefit from it.
    The plan is VERY simple and quite "bright" - pun SO intended 20w LED lamp, drill bit, screw onto wall above my door, run wire into my house so nobody can say I run it off the building's bill and switch it on and off with an RF remote when I need it to. A PIR sensor is not an option since it would trigger when others pass by too, which is pointless and would make the situation even worse, since it's the complete opposite of what I'm trying to achieve here (OTHERS would draw power from MY grid - go figure). The RF remote would allow me to turn it on when I'm just about reaching my floor and then quickly turn it off once I'm inside and vice-versa when I'm leaving.
    The problem is the remote control module: while there are MANY different models to choose from that fit my requirement of having the smallest possible key fob-style remotes (you don't want a TV remote control in your pocket, do you?), I COULD NOT find one that has more than 2 remotes and I need at least 3 because that's how many people would need to be able to switch the light. Looking around at various of these generic RF modules, intended both for actual home automation purposes and for car use (doesn't matter, since it'd be just as easy to adapt it), I noticed the vast majority have the same circuit inside, or at least really similar ones, yet nobody could give me a clear-cut answer whether it'd be possible to obtain and register additional remotes for them. Answers ranged from "Don't know - I'm just selling them, I have no idea how they work" to "probably"....wouldn't want to get one and have it turn into a white elephant....
    I'm aware it's impossible for people outside my country to know what's possible to get and what's not and how the tons of different models out there operate exactly, what they do and what they can't do, but perhaps it's just the looks that differ while still keeping the same basic principle which can be hacked into. Say I get a remote that looks different from the ones that come with the module, I SHOULD still be able to register it SOMEHOW. If others have done this before or have an even better solution, I'd be grateful to hear it, as long as it doesn't go too crazy like using arduinos over wi-fi to control it with our phones or other such over the top solutions Someone might suggest something off ebay that maybe looks similar to something I'd able to source locally too...cheers and thanks for any input Good project to learn about RF and remotes too
    Wattevah...
    • 31083
    Re: Adding remote to RF central locking unit (project)
    the chinese sell a 4channel radio-remote plus reciever with relays in it dirt cheap on ebay/banggood
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I have searched for one of those but maybe I didn't dig deep enough because I couldn't find anything significantly different from what I found here which have 2 remotes. I'll keep on looking, but in the meantime, if you happen to had come across such a thing, could you drop me a link ?
      Wattevah...
        • 31083
        enjoy
        https://www.banggood.com/search/wire...l?sortType=asc
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          You wrote an additional "gretting" at the end there too :P
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Had a look at what you linked to, but I'm having the same issue: none of these seem to come with more than 2 remotes and they don't seem to provide additional remotes as an option either. In fact, I came across many of those here as well, which would certainly be more convenient as it would do away with the hassle of waiting for postage if I can find one that has 3-4 remotes. I'll also try checking with some locksmith shops to see if any can clone a remote for a car central lock, since many shops offer such service nowadays with wireless fobs being the norm and it'd be easier and quicker to adapt one of those instead.
            Wattevah...
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • cstout
              DeLonghi AC Remote only accepts 3V
              by cstout
              Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
              The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
              I can't find any schematics...
              06-03-2024, 03:53 PM
            • Mc_Millian
              Toshiba 50lf711u20 fire tv remote not pairing
              by Mc_Millian
              I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
              The Tv model number is: 50lf711u20 Rev B.
              I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
              I've tried 3 different remotes which should be fully compatible with this TV.
              Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
              The power button, along with the volume,back,select, and directional...
              04-07-2022, 12:15 PM
            • edugimeno
              HiSense 55A7500F won't obbey to remote after power on
              by edugimeno
              Hi! I have this TV set that does the following:
              1) I press the red power button on the remote
              2) The TV turns on normally
              3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
              4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
              Then after it's off, it would again accept the TURN ON from the remote and same again
              BUT:
              -The remote does show the correct IR beam while observed thru a phone camera
              -The TV works fine while using the MiRemote...
              03-14-2023, 11:22 AM
            • tmhobadcap
              Pioneer VSX-522-K remote control not working???
              by tmhobadcap
              I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
              At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
              12-24-2020, 01:44 AM
