Detecting A Bullet
  • EasyGoing1
    replied
    Re: Detecting A Bullet
    Originally posted by eccerr0r
    Yeah the sound sensor probably will work fine.
    I bought an Arduino configured audio sensor that lets you adjust the ambient sound threshold then anything that exceeds the ambient sound will trigger a pin at 5 volts. It works well and might suit the application. The only thing it won't be able to do is determine which target from multiple targets was actually hit, but that's not a big deal really since visual inspection will be enough in this application.
    I'll report back when I test it, but that might be a while.
  • GeorgeBlitz
    replied
    Tech is not usually the best answer for downrange systems. It's easy to damage anything on the far side of the trigger, so it's best to stick with Cheap/Easy.
    I do what you're talking about frequently, for 5.7x28 practice. I buy the electric yellow day-glow paper, stack it, and cut it to a size that will patch my targets' impact marks. Even a pellet gun hit shows up instantly on that stuff.
    Bonus: I save money by closing up my groups.
  • theojt
    replied
    Not sure if it would work for you but TargetImpactSignal.com makes sensor that triggers a photo flash to indicate target hits. The cheapest one is about $99. Their sensor (could be piezo by the description) is $50. Theirs is designed to go on the back of a metal plate target but could possibly be adjusted for appropriate sensitivity to poster board/cardboard. I'd have a chat with them at least to validate the feasibility. I'm not affiliated, just read about them.
    http://targetimpactsignal.com/how-it-works/
  • Andyy
    replied
    I remember an episode of Mythbusters http://www.youtube.com/watch?v=2qY0DA7DG9s where they used a simple apparatus consisting of two pieces of foil separated by a thin insulator (like kitchen cling wrap film). When the bullet pierced the foil and insulator, the foil would make contact with the other foil, closing a circuit.
    I'm not sure if it's adaptable to your scenario though.
  • eccerr0r
    replied
    IR (light) beam IS fast enough, but as said earlier, devil is in the details, hence abandoning it for sound. Need an intricate system of light pipes to make light work with a reasonable number of sensors (which cannot be scanned in an array, they need to be detected all in parallel).
  • petehall347
    replied
    ir beam might be quick enough ..may need a lot of beams though
  • eccerr0r
    replied
    Yeah the sound sensor probably will work fine. The PIR sensor is probably just not sensitive enough to detect a small bullet (they were designed to detect humans or parts of humans), but speed might be artificially reduced to filter out noise since humans usually don't move as fast as bullets. So you may still need to design your own.
    Note that using bluetooth you will have to add more delay as BT also adds latency. Should be in the millisecond range however.
    Gunpowder explode -> microphone sensor = speed of sound in air
    microphone sensor -> initial processor = instantaneous
    initial processor -> bluetooth = packetization latency+processing (~1-2 milliseconds)
    bluetooth -> main processor = bluetooth and depacketization latency (~1-2 milliseconds)
  • EasyGoing1
    replied
    Will the shooter be in a stall? You can place it closer to the shooter than the target, or even have the sound detector in the pocket of the shooter and possibly wirelessly transmit the data as light is faster than sound.
    No, the shooter will be standing outdoors ... desert kinda terrain. The wireless option MIGHT be dooable ... would have to explore that a little more. One thing I like about that idea is that if we used bluetooth, and there are multiple shooters - each one could get their own mic and I could track which shooter is doing what.
    The microphone wouldn't even matter much I think, you can use any old audio range speaker, piezo element, microphone, or whatnot. The gunpowder explosion causes so much noise whose amplitude is probably high enough to be picked up by nearly anything pointed at the right direction. But you will have to experiment to be sure.
    I just ordered these
    and I saw these when I was browsing ... do you know anything about these motion sensors? You think they might be too slow or unable to detect something as small as a bullet?
  • eccerr0r
    replied
  • EasyGoing1
    replied
    If accuracy is not a concern, then the original solution by stj should work (though it need not be on the target)? If we don't care if we get a bullseye, then the loud BANG! noise generated by the explosion of the gunpowder can easily be detected via sound?
    That's something I had not considered ... I thought sti was suggesting placing microphones onto the wood that the target might be mounted on to listen for the bullet hitting the target ... listening for the loud bang might be an idea ... but two things come to mind when I think about this a little more:
    1) A bullet travels faster than sound ... so in theory, the metal detector would be more responsive and more accurate when determining the shooters response time to a light turning on as opposed to just waiting for the audio from the gun ...
    2) We were at the range yesterday and I was wearing active audio ear protection which allows you to hear people talking until the ambient audio reaches a high enough decibel, then it kicks in some circuit that reverses the audio wave and cancels it out before it hits your eardrum ... $20 at Harbor Freight Tools ... they work amazing ... but the protective circuit kicked in a lot because of other nearby shooters ... and I'm thinking that such a solution would be difficult if not impossible to limit the detection to the shooter that I am interested in... and not some other shooter who is in the same range as me or the one next to me.
    I suppose an argument could be made that if the audio equipment being used was sensitive enough or the circuit was discerning enough, then we MIGHT be able to tune the sensitivity so that only a nearby gun would provide enough amplitude and be much higher than the amplitude of near by shooters ... perhaps with some kind of a can or a tube that is pointed at the shooter that we're interested in that also has baffles built in that would block a significant portion of audio from nearby shooters ... hmmmm ... might have to experiment with that ... as audio would be much easier ...
    But would it be fast enough ... need to run the calcs that show how quickly a sound wave would hit the microphone at ... maybe 20 yards max distance...
    ok, some quick and dirty calcs show that an audio wave traveling at 343 m/s converts to roughly 375 yards per second ... just looking at it, I'm thinking it will be fast enough, but if I divide 375 by 1000, I get .375 yards per millisecond ... which when divided into 20, it gives me about 53.3 milliseconds of delay time between when the shooter pulled the trigger and the Arduino hears it ... that's an acceptable margin of error, because I could easily subtract it back out of the calculated time, and be even more accurate than if I didn't ... also with my tests using buttons instead of guns, I'm getting response times in the hundreds of milliseconds, so I'm sure that even 53 milliseconds would be low enough to call it good enough.
    Another thought ... sound travels at the same speed all the time, no matter what caliber bullet / grain you're shooting ... so from that perspective, it would even be more consistent when looking for someone's response times where detecting the presence of a bullet might indicate a slower or faster response time depending on the bullet... so from that point of view, dealing with known and consistent variables like the speed of sound ... might end up yielding a better solution in the long run..
    But the metal detector idea sounds funner ... but admittedly more difficult to do ... AND, I COULD tell the software to not listen for any sound until the correct light is lit at which point, id only be opening up the monitoring for less than two seconds so my chances of getting false positives from nearby shooters would then be limited to a significantly smaller time window GREATLY reducing my margin of error ....
    I've got some of those really cheap and very common LM317 (i think opamps ... maybe if I could find a good schematic to start messing with I might be able to come up with something...
    but I'll need a mic ...
    (as a side note) Going to the range was a birthday gift to me - I got to shoot a brand new AR-15 at targets 120 yards down with iron sights - and I hit the paper plate with over 90% accuracy ... not bad for a guy who hasn't shot a gun in over 20 years. That AR-15 had ZERO recoil on the rifle ... that and I got to shoot a couple of hundred rounds of 9mm rounds while being trained by a certified NRA instructor (the friend of mine who took me shooting and who wants this project done) ...
    Sorry for the long post today ... .did a lot of thinking out loud with my fingers it seems
    Thank you again for taking the time to discuss this with me,
  • eccerr0r
    replied
    Originally posted by EasyGoing1
    This isn't really a problem. It's easy to see whether or not the shooter hit the target. If they didn't, then the results of the detector will be ignored. What cannot be done visually by a human, is determine how quickly the shooter responded to an event that is generated by the microcontroller, so all I need, is the shooters response time to an event ... I don't need the technology to confirm that they actually hit the target.
  • EasyGoing1
    replied
    See the problem is that if the bullet passes outside of the loop, it could also get detected as inside as it can't really tell.
    The back of envelope calculations here say that a 1000m/s bullet that's about 4cm long or so traveling near a metal detector will pass through it in 10µS or so. The detection wavelength needs to be faster than this so likely at least 100KHz or so...
    I'd be using a double loop "air transformer" and the bullet would temporarily become a metal core. We'll be detecting the permeability change of air versus a metal object. However the object is small, so we'll need to pump up the power such that it can be detected... this would require quite a bit of power that could possibly generate RF noise...
    After my last reply to you, I looked up some articles on metal detection, and I think we might be looking to implement a Colpitts Oscillator - which seems to be the most popular method of metal detection. From what I can tell, using a multi-wire loop as big as maybe 20 inches in diameter or larger shouldn't be a problem - as you said - with enough power. I'm sure a 12 volt power supply with a couple of amps capability would be more than enough. And 100kHz seems to be the common frequency chosen for these circuits.
    I still say do it via light. Light doesn't care about getting hit by bullets.
    I agree, but cost constraints would seem to limit this option unless I can use some kind of inexpensive LED solution that would cover a 20 to 25" radius ... off the top of my head, would be possible to use a couple of infrared LEDs with infrared receivers, then somehow send a known timing signal out of the IRLEDs then detect maybe a change in magnitude as the bullet passes through? Might even be able to use the Arduino as both the signal generator and the signal monitor at a high enough frequency to detect the change.
    What are your thoughts on it?
    Thank you again,
  • eccerr0r
    replied
    See the problem is that if the bullet passes outside of the loop, it could also get detected as inside as it can't really tell. So unless you have a really big target zone and don't care about accuracy, then possible (but I suspect it defeats the purpose of such detector).
    And no, 555 will not work. Because the bullet is traveling so fast, you need to be in the MHz region at least, need to do some math for feasibility here...
    I still say light. Bullets may be fast, but do not get close to the speed of light.
    Thinking out loud here. I don't have any documentation of metal detection handy, this is all done in theory, at least if you haven't seen any documentation about it, it might not actually be feasible unless tried. The back of envelope calculations here say that a 1000m/s bullet that's about 4cm long or so traveling near a metal detector will pass through it in 10µS or so. The detection wavelength needs to be faster than this so likely at least 100KHz or so...
  • EasyGoing1
    replied
    Normally you'd use some sort of metal detector system like what you'd use going through the airport but these things would be sensitive to both "inside" and "outside" of the loop. Plus if someone hits the loop, it's time to get a new one.
    I thought about that. I'll talk to the guy who wants this done about protecting the sensor and see what his thoughts are on it, but as far as detecting a bullet that passes outside the target zone, I think that's not so relevant because what we're looking for is the shooters response time to an event ... a light turns red, the counter starts, they draw their firearm and shoot. The sensor records the bullet then the time delta is recorded.
    Do you have any more information on the 'metal detection' method you're thinking about? I kinda need to do this on the cheap and was thinking if I needed to just get some transformer wire and create a loop using many wraps of wire, that would make the most sense in terms of cost ... what I'm unsure of, is how the loop should be constructed (wire type and gauge, number of 'wraps' etc.) and also the circuit required to both generate the field and detect any changes in the field. I'm assuming that I need something based on a 555 perhaps, and some opamps to amplify the signal while reducing noise etc. but for all I know, there may be an IC out there somewhere that performs these functions better than I could with a constructed circuit ... just looking for as much education on this as I can get my hands on.
    I've already got the Arduino software written using buttons as mock bullet detection sensors, and it's working pretty well. It detects response time at millisecond accuracy.
    Thank you again,
  • eccerr0r
    replied
    If this is indoors under consistent lighting, the other option is perhaps light pipe/fresnel lens and trying to detect minute light differences much like PIR, except it must be active light detection to reduce scan costs. Have two of these, one in X and Y direction; and if both X and Y detect something, then we have the bullet passing through that region. I think this can be made small enough that it might be reasonable enough to protect it from stray shots. Then again if you can move the sensors far away from the target hit box region then protection might not be an issue.
    Light pipe will be necessary with coherent light (probably low power laser) to not affect the other sensor.
    This is not going to be an easy sense but much cheaper than the camera system, and it would be a square/rectangular sense region. If you do a 3x3 matrix or more of these, then you can have even better resolution of where the shot hit.
  • eccerr0r
    replied
    I'd going back to using a very fast (and expensive) camera system to detect it.
  • EasyGoing1
    replied
    Okay, to be explicit for more details...
    Do you care where (X,Y) in the region the bullet goes through? (i.e., are you using this as target practice?)
    How big of an area?
    Can you tolerate using a magnetic field that may alter the trajectory as the bullet goes through?
    Will there be some other backing (target paper) or will the area need to be free space?
    Excellent questions!
    So the targets will be fairly close to the shooter ... the furthest distance may be 10 to 15 feet away at the most.
    They are humanoid style targets, so the area we need to detect would be approximately a circle (or maybe oval if it doesn't prove to be too difficult) that would essentially cover the chest region of a 6'2" human male.
    Altering the trajectory of the bullet within reason is perfectly acceptable, I only care that the bullet gets through whatever I'm going to use as the sensor. Doesn't matter if it hits dead center or the edge. I have no interest in where it hits, only that it hits a defined region of the target.
    The targets will have some backing, but there is concern that as they get used, bullets CAN - on rare occasion - pass through the same point which seems to eliminate the option of using any kind of a concussion phenomena to detect the bullet as has been suggested in this post already (no audio option where a bullet might hit a board or something). The desire is definitely to employ some kind of an electromagnetic field that could be disrupted by the bullet and detected.
    Also, we aren't interested in the speed of the bullet (in case anyone was wondering about that). We only care about whether or not it passed through the sensor region.
    Thank you very much,
  • eccerr0r
    replied
    How big of an area?
  • EasyGoing1
    replied
    What about this whole idea of some kind of wire that is wrapped multiple times in a circle then the bullet creating a magnetic ripple in the wire and detecting that? Anyone know how something like that works or what principle it is?
  • eccerr0r
    replied
    I'd ask for more details else I'd go for an expensive optical solution because I don't like the idea of my electronics creations getting shot at...
  • Takeatry
    Yet another Samsung QLED Boot Loop
    by Takeatry
    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
    10-04-2024, 02:57 PM
  • blaster_
    Samsung UE49MU6105K - boot loop, horizontal lines
    by blaster_
    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
    06-22-2022, 05:19 PM
  • Stefano Crivellari
    Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
    by Stefano Crivellari
    Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
    01-14-2025, 03:49 PM
  • ferah831208
    HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
    by ferah831208
    I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
    12-07-2024, 04:02 PM
  • NolesFan
    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
    by NolesFan
    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
    10-24-2024, 06:36 PM
