eBay 5 volt @ 15 amps switching power supply any good ?
    • Jul 2011
    • 6070
    I would like to know if this brand of power supply is any good
    http://www.ebay.com/itm/Traco-Power-...41722#shpCntId
    • 31277
    Re: eBay 5 volt @ 15 amps switching power supply any good ?
    electrically it's probably good.
    but mounting it will need a rail or some type of center support.
    also the reference to leds is worrying - that would need regulated current rather than voltage.
    you would be better with a rectangular caged supply tbh.
    have you seen the ones used in arcade equipement?
    5v @15a, and 12v / 24v and caged.
    http://www.arcadeshop.com/d/51/power...parts-kits.htm
      03-31-2024, 02:12 PM
      After all of...
      07-13-2024, 08:14 PM
      Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
      I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
      I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
      I used a four USB outlet and electrical plate that is made for...
      08-03-2024, 07:54 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      DVR camera recorder switching power supply capacitor failure really
      These cheap non brand capacitors at it again
      Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
      Well at least I have the cameras back on line I to try the...
      01-22-2022, 06:28 PM
