Help Sourcing A Part
  • GUARBorg
    • Jul 2015
    • 6
    I have a couple through hole diodes I haven't been able to source. Does anyone know of a good site or database I can check to decipher the case markings? I have plenty of sites for SMD parts but nothing devoted to obsolete through hole components.
    First is a orange/black glass sealed diode (probably a zener) with a case code of 135.
    The second is a standard looking diode with either "9H" or "H6" with a vertical "37"
    These parts are 10-15 years old if it helps.
    Re: Help Sourcing A Part
    If we can see the good pictures of the board to see how that diode is connected in the circuit then we may be able to determine its function.
    • elektrosercen
      • Oct 2017
      • TURKEY
      Here is the largest of smd code list page
      http://chip.tomsk.ru/chip/chipdoc.ns...at=A&count=500
      and another one http://www.systek.ru/marking.php
      i hope this helps you
      • Nweihi
        • Oct 2017
        • 4
        • Jordan
        • NeedsMoreFlux
          • Oct 2017
          • 121
          • California
          You might be interested in getting a sub $20 ebay component tester.
          I bought one and have used it a few times and I love it.
          Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
          I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
          Some of the things I've fixed:
          60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • Yanleb
            Panasonic part number in service manuals
            by Yanleb
            In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
            This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
            For an example, look at the attached PDF.
            Do you have a way to cross reference the Panasonic part number with the actual part number?
            Thanks....
            07-03-2023, 08:16 PM
          • FreakyMex
            Trouble to identify part (Lunii screen) for replacement
            by FreakyMex
            Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
            I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
            02-17-2025, 01:16 AM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
