Hooked up 12v fan to rework station causes power reset
  • xboxhaxorz
    • Jan 2011
    • 196
    I have an IR6000 and i installed a 12v fan to it, it already has a 12v fan for the top heater so i simply cut the 2 wires and bridged them for the new fan to use for the bottom heater with the existing switch
    The fan works just fine, however sometimes when i flip the switch the machine resets ie; it turns on and then off
    If i leave the switch flipped on and turn the machine on the machine kind of pulses on and off until i turn the flip the fan switch off
    Sometimes turning the 12v led off and back on makes it work, the 12v led is not on the same switch but its on the same enclosed power supply
    The other components such as heaters and controllers are directly on 220v not going through the power supply
  • redwire
    • Dec 2010
    • 3912
    Re: Hooked up 12v fan to rework station causes power reset
    It looks like an internal 12VDC 1A power supply for the two PID controllers, lamp, top fan, case cooling fan... Depends on the build you got.
    I think there is no reserve to run additional load like your extra fan.
    Or the PSU (caps) is getting weak, it does run in a hot place.
    You could add a big capacitor on the 12V output like 1,000uF or measure the current drain on the 12V rail, see if the power supply is undersized or not.
    I don't know a lot about using this station, but adding a bottom fan will change the PID tuning for the bottom heater.
    • xboxhaxorz
      • Jan 2011
      • 196
      That was my thought and your right about the PSU rating, it was just weird that it would reset the PIDs as well since they are directly 220v and not going through the PSU
      All i had was a 36 ohm resistor so i tried that which worked and also reduce the speed obviously, so yep the PSU was underpowered
      Thanks, case closed lol
      • minimania
        Need Schematic for jbc am6800 rework station
        by minimania
        hi all im looking for a Schematic for jbc am6800 rework station
        mine has stopped working fully
        it started with turning off when switched on then after a few off and ons it worked sort of for awhile
        now it wont turn on at all...
        01-28-2025, 03:44 PM
      • shahnld
        Seamark ZM-R6200 Rework station
        by shahnld
        Good day Experts.
        I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
        Kind regards
        01-24-2024, 10:55 AM
      • petemanuk
        Help with IR6500 rework station
        by petemanuk
        I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
        1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
        2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
        10-14-2022, 12:31 AM
      • EvazX
        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
        by EvazX
        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
        However, after some time, the replacement motherboard...
        08-25-2025, 06:09 PM
      • Peter_1402
        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
        by Peter_1402
        Hi Everyone,
        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
        1. Soldering iron works great
        2. There is a burnt mark on the hot air gun handle.
        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
        Reed switch tested ok with a magnet.
        From the above test, I can conclude...
        07-12-2025, 11:50 AM
