Suggestions for a 4-way switch.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Re: Suggestions for a 4-way switch.
    Originally posted by eccerr0r
    yeah it looks like yours is the same, should work.
    About the SPST (the regular kind) switch - Well, when you short two wires together, you can either complete a circuit or completely destroy your house... I call the former a "control" circuit, and the latter a "power" circuit which should be connected to an receptacle...
    I understand the switch and how it works. I'm still struggling a bit with this power circuit. I've always looked at switches as sitting between the hot and the light (or load). So with a 2-way switch, you'd interrupt the hot going to the light by adding the switch. When the switch is off, the circuit is broken and no juice goes to the light, when the switch is on, the circuit is complete and juice goes to the light.
    How would it be wired for a power circuit? Would the switch be interrupting the juice going to the receptacle or would it be wired somehow where it could still control the light but somehow needs the receptacle to not blow a fuse / trip a breaker?
    Maybe drawing would help me. Even though the 4-way is figured out now, I'm always interested in learning, especially in subjects where I still lack the fundamentals. I'm slowly learning about AC but for the most part, I only learn about it when I need to do something with it. I haven't sat down and picked up on books on it or anything like that.
    You seem to know a lot more about AC than I do and I appreciate you sharing your knowledge.
    I just searched google, and from what I've found, I think if I'm understanding it, I have a power circuit. A control circuit would be a maybe a switch that operates a relay that controls a large amount of current. Is that correct? Or can the term differ depending on which site you're at? I picked this up at https://c03.apogee.net/contentplayer...d=wppi&id=4703
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      If you have $20 to do the job and half the wire is inside the wall already, sometimes you don't have a choice...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8696
        actually might just be reading into it too much, it was meant to be an oversimplification of when you get a 12-2 wire dangling to you and you don't know how to classify it... I just classify as "control" if you short the two and something else turns on elsewhere. If the two wires come to you supplying power (whether by an upstream switch or not), then that's a power wire which would be very bad if you short the two with a switch or wire nut.
        It is an oversimplification because you can have two things that could be called "control" in series, but once you truly designate one a "control" the other instantly becomes "power"... which does make the terminology confusing.
        Warning: IANAE and I do not know NEC - alas electricity frightens me and I treat it very carefully.
        • Spork Schivago
          • Mar 2012
          • 4734
          I gotcha! Thank you so much for explaining it to me and now I understand what you mean by power and control circuits! That makes sense and I believe I understand the purpose of the receptacle now. This was important to me, because I plan on replacing all the switches / receptacles in the house and wanted to make sure I didn't make any terrible mistakes.
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
          • Natob82
            Micro Momentary Push Switch?
            by Natob82
            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
            12-21-2022, 05:22 AM
          • grimacelord
            NEC TurboExpress On/Off Power Switch Replacement Help
            by grimacelord
            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
            11-09-2023, 09:49 AM
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
