The differential amplifier.
  • capwizard
    • Jun 2016
    • 1991
    This is the best video I could find about the most importance of Differential Amplifier. Let me ask you What is current mirror?
    #193: Back to Basics: the differential amplifier, aka long-tailed pair, diff-pair
    https://www.youtube.com/watch?v=mejPNuPAHBY
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: The differential amplifier.
    look up ocl-techguide.pdf ...
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Notation rarely used this current mirror , who said that and from where did you get it capdude ?..
      I think the right notation is Amplification distortion limiter via Input vs Output maximum capability , related to Linear or non linear Amplification design ..
      • MrCommunistGen
        Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
        by MrCommunistGen
        My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
        I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
        07-12-2021, 05:11 PM
      • jinu_j
        How to test Subwoofer Amplifier with only a multimeter
        by jinu_j
        Hi Folks
        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
        Problem
        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
        Any advice would be appreciated...
        08-29-2024, 02:05 AM
      • UserXP
        Mackie CR4 amplifier no sound
        by UserXP
        Hi, people.
        I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
        Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
        10-17-2020, 05:06 PM
      • Coert van Dorsten
        Sansui Integrated Amplifier replacement volume control troubles
        by Coert van Dorsten
        Hi all you clever electronmic gooroos!
        I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
        10-15-2025, 02:54 PM
      • mikey5791
        Help on car amplifier only one channel works
        by mikey5791
        Hi all forum members,
        Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
        My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
        08-06-2025, 10:36 PM
