Any idea what can I do with this?
  • capwizard
    • Jun 2016
    • 1991
    Any idea what can I do with this? Recycling gold is no partially....and the soft layers of the LED screen, I've use it to print the business name cards but I do not need so many, Any idea what can I do with this?
    ______________________________________________
    After Inauguration, Trump, he is He and H.E. ! . . .
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Any idea what can I do with this?
    If you don't have the necessary Chemical techniques , or unwilling to pollute the whole neighborhood , then better sell them at Ebay or Amazon . Name your price and wait for the right customer .
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      please explain how you make business cards out of those...Always thought I should do something with those layers,too neat to just throw out.
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • capwizard
        • Jun 2016
        • 1991
        Dear martino: Recycling Around the World......................
        Step1: Download business card template.
        Step2: LED screen plastic layer cuts to A4 size
        Step3: print it and cut it to the business card size
        Step4: FIN
        PS: I would like to know more recycling ideas for plastic layers? Reduce, Reuse, Recycle
        PS: Look! pic4 has A Rainbow?
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Ha! That's awesome. I'm gonna have to try that out,looks great. How does the ink hold up?
          • capwizard
            • Jun 2016
            • 1991
            I use Monochrome Laser printer Samsung SCX 4623F.
            • capwizard
              • Jun 2016
              • 1991
              Making A PCB.
              No-etch circuit boards with your laser printer...........I gonna try this one.....AA-DUCT AD1 Low Cost, One Part Heat Dry Electrically Conductive, Silver Epoxy Adhesive.......................
              https://www.youtube.com/watch?v=mwwA1d2s2OQ
              Inkjet Printable Circuits
              https://www.youtube.com/watch?v=V0AHc3CA9NU
              Print Your Own Circuitboards with Voltera | Hardware Battlefield
              https://www.youtube.com/watch?v=OqcAm7xGWJM
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • evilkitty
                Any idea what happened (wifi acted up)
                by evilkitty
                I have 2 access points, one a U6-LR and WZR-300HP running DD-WRT v3.0-r28444 (has had stable wifi since 2015)
                and i am trying to work on my PICO W and it suddenly would not connect and my computer had a very hard time connecting and my dad had been complained about his phone connecting
                so i ran a wifi scan script on the pico and it just hang for several seconds and found nothing, normally it would spit out every AP in under a second (both of mine and some neighbors)
                What i did was just install a U6-Lite that i had not gotten around to installing to replace...
                09-01-2023, 12:27 PM
                Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
                by sam_sam_sam
                My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
                06-22-2025, 10:23 AM
                New project idea making a lipo 2s 6 volt lantern battery pack for lantern flashlight LED version
                by sam_sam_sam
                Sense these battery packs are hard to find Also for the incandescent light bulb version as well
                Sense I found a 6 volt BMS board I decided to make a couple of them with a charging port on the side of lantern to charge the battery pack
                11-24-2024, 06:05 PM
              • Mike_Ho
                Any Idea for repair L13 Gen2 LAR-2 PD Charger Mosfet CSD87501L always Burned
                by Mike_Ho
                Dear All
                Anybody have experience to repair L13 Gen2 Board Number : LAR-2 PD charger problem?
                I have one board the U4201 CSD87501L are burned and the 20V_VBUS_USB2 can't switch to 20V_VINT_IN, after replace this Mosfet it's still very HOT and just use few hours will burned again. i have repeat replace this Mosfet 3 times and all dead.
                After that i try to shorted Mosfet Source 1 to Source 2 to bypass the 20V, and found the Control Gate 1 and Gate 2 voltage both are 20v same with 20V_VBUS_USB2.๐Ÿคจ
                So did anybody know this case will need to replace...
                03-15-2024, 02:02 AM
