Replace 8Mb bios chip with 32Mb possible ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I need to replace a At26df081a-su, I already have a At26df321-su in my box - Is it possible to replace a 8 megabit chip with the 32 megabit ?
    Will motherboard just use the first 8Mb of the 32Mb chip and contine to work as normal ?
    AT26DF081A datasheet vs AT26DF321 datasheet
  • Exras
    • Jan 2017
    • 7
    • Denmark
    Re: Replace 8Mb bios chip with 32Mb possible ?
    Interesting, I've never looked into serial memory addressing, 2764/27512 Eproms was the shit when I was young.
    But looking into the pdf's
    Pin 7 !HOLD is not in use on the 32Mbit chip
    The HOLD pin is used to temporarily pause serial communication without deselecting or resetting the device...
    But is it needed I don't know, motherboard schematics? properly not..
    The serial addressing looks to be compatible and will only use the first 8Mbit as you suggest.
    Commands and Addressing:
    Addressing of the device requires a total of three bytes of information to be sent, representing address bits A23 - A0.
    Since the upper address limit of the AT26DF081A memory array is
    0FFFFFh, address bits A23 - A20 are always ignored by the device.
    address bits A23-A0. Since the upper address limit of the AT26DF321 memory array is
    3FFFFFh, address bits A23-A22 are always ignored by the device
      by SMDFlea
      Bad...
      09-02-2021, 04:40 PM
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • inck243
      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
      by inck243
      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
      The BIOS...
      07-25-2024, 09:17 AM
    • ed1i
      Dell Inspion 7610 bios chip
      by ed1i
      Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
      01-16-2025, 02:14 PM
