Replace 8Mb bios chip with 32Mb possible ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I need to replace a At26df081a-su, I already have a At26df321-su in my box - Is it possible to replace a 8 megabit chip with the 32 megabit ?
    Will motherboard just use the first 8Mb of the 32Mb chip and contine to work as normal ?
    AT26DF081A datasheet vs AT26DF321 datasheet
  • Exras
    • Jan 2017
    • 7
    • Denmark
    Re: Replace 8Mb bios chip with 32Mb possible ?
    Interesting, I've never looked into serial memory addressing, 2764/27512 Eproms was the shit when I was young.
    But looking into the pdf's
    Pin 7 !HOLD is not in use on the 32Mbit chip
    The HOLD pin is used to temporarily pause serial communication without deselecting or resetting the device...
    But is it needed I don't know, motherboard schematics? properly not..
    The serial addressing looks to be compatible and will only use the first 8Mbit as you suggest.
    Commands and Addressing:
    Addressing of the device requires a total of three bytes of information to be sent, representing address bits A23 - A0.
    Since the upper address limit of the AT26DF081A memory array is
    0FFFFFh, address bits A23 - A20 are always ignored by the device.
    address bits A23-A0. Since the upper address limit of the AT26DF321 memory array is
    3FFFFFh, address bits A23-A22 are always ignored by the device
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • inck243
      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
      by inck243
      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
      The BIOS...
      07-25-2024, 09:17 AM
