Spend whole month to find this intermittent problem.
  • capwizard
    • Jun 2016
    • 1991
    Spend whole month to find this intermittent problem over this customer's Compaq pc tower.
    Yes, 2 pennies inside. I have to say my two cents on spanking your kid just let him swallows that 2 pennies.
    • 31277
    Re: Spend whole month to find this intermittent problem.
    2 pennies?
    i found a whole bank debit card in a ps4 that wouldnt take disks!!!
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      To funny.
        • 31277
        Originally posted by keeney123
        To funny.
        yea, but shows you have to look for the unexpected!
        • diif
          • Feb 2014
          • 6978
          • England
          Working in a school did that ! The kids used to love feeding their spare change and crisp/sweet wrappers into the floppy slots.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            when i was living in a rented place, i found a swimming pool membership card in my hdd-dvd recorder's dvd drive. and like stj said, it wouldnt take discs due to the card in there. dunno who's the asshole roomie who put it in there...
            • protocold
              MacBook Pro 15" 2010 820-2850 intermittent charging
              by protocold
              I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
              I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
              when it is not intermittent:
              PPVBAT_G3H_CHGR_R is 12.07v
              when it is intermittent:
              When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
              when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
              data line on the battery...
              07-25-2025, 08:18 PM
            • C152Heavy
              by C152Heavy
              Summary for TL-DR readers:
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
            • wesc0
              MSI G513QR - G533-6050A3250201-MB-A03(A3) - Intermittent Charging
              by wesc0
              Hi all, have a strangely behaving laptop that's giving me issues. It charges thru the barrel jack, but when I watch the battery indicator in BIOS, the charging indicator flickers off and on. When I plug the charger in, I hear hissing from around the area of L67050. I also had an intermittent issue where the fans weren't spinning up at all, allowing the CPU to reach 100C+ in BIOS and OS - this cleared itself up after I left it overnight but of course I don't trust that it'll stay that way. USB C charging works fine.
              Any advice or direction is greatly appreciated! If there's any...
              09-30-2025, 07:58 AM
            • Zippo978
              Telefunken te43550b40q2k intermittent backlight
              by Zippo978
              Good morning everyone
              I have this Telefunken te43550b40q2k TV that has intermittent backlighting, sometimes it turns on and then does not turn back on.
              I tested the LED bars and all three work, not even one burned LED, then I tried to put only two bars short-circuiting the end of the connection cable and it does not give any problem the LEDs stay on without problems, I also tried short-circuiting the central connector and the initial one, always no problem, but as soon as I put the third bar, no matter the position the problems start again.
              Thanks in advance...
              09-04-2024, 01:35 AM
            • BigPete
              Intermittent display on Sherwood Newcastle R-965 Receiver
              by BigPete
              I'm working on a Sherwood R-965 at the moment. It came in with relays clicking constantly and also going into protect mode.
              I've re-soldered a lot of dry joints and replaced quite a few capacitors and now it works, but I still have one problem I haven't solved and would like some opinions.
              The vacuum display is quite intermittent. Sometimes it won't turn on, sometimes it will turn on but the characters, numbers and letters are frozen on, regardless of which buttons are pushed. And sometimes it works flawlessly. If the display doesn't turn on initially, restarting...
              08-25-2024, 02:48 AM
