Full-range input, 120V output UPS
  • Behemot
    • 4845
    • CZ
    Not sure if it's the right section, but it's not about repair…
    Customer would like what basically is an on-line UPS with full-range input and 120V 60Hz output. Frequency/voltage converter as he put it which is also battery backuped will be almost impossible to get so I have been looking after UPS only.
    What was my surprise that the cheap morons produce just full-range 230V output, but not 120V output UPS. Plus there is usually some auto-detect crap for frequency - I need 60 Hz no matter what goes inside. Any tip?
    • 31094
    Re: Full-range input, 120V output UPS
    you need a 2 stage design.
    first a buck/boost supply to create a dc voltage of say - 60v, then an invertor to get the output.
    you can get chinese buck/boost circuits, but what input range??
    • Behemot
      • 4845
      • CZ
      No, I need on-line UPS with buck/boost controller. Ordinary ones have boost controller, but I don't think its that complicated to make it run buck/boost, almost all the things are already there.
      If it is say 120V nominal, than it is boosted to higher voltage anyway, and only than a clean 120V nominal sine-wave is created. The only difference is it most likely boost to something like 200 V from which it switches 120VRMS sine-wave. All I need is for the inverter to be able to work with 315 V DC bus.
      Don't want any of them stinking chinese crap, from what I've seen most of them are PoS. Even if it has sine-wave, which usually does not, it is made in strange design. Just got an inverter which I'll post here soon, it is basically 8 parallel-driven inverters together. How surprising it failed…
      I think them US boys may know about something since this voltage is what they use.
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
      • EasyGoing1
        Reading input and output of bridge rectifier on the same scope?
        by EasyGoing1
        I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
        When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
        06-26-2022, 12:52 AM
      • ugamazing
        820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
        by ugamazing
        So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
        1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
        2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
        04-10-2024, 08:06 AM
      • gjgib
        Help reading schematic voltages input/output
        by gjgib
        Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
        I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
        I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
        I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
        05-06-2024, 08:11 PM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
