What component ?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: What component ?
    As I look closer I saw a couple more. It is hard to tell by the picture. I have circled in red where I question the connection.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Originally posted by bianchi77
      Some photos :
      You need to use a black background under the board turn the flash on the camera "off". If you take the picture outside and use natural light take the picture before 10 am or after 2 pm. If you take the picture inside do not shine light directly on board. Make the light around the board bright enough so the picture snaps quick enough so there is no blur. An make sure camera is on macro.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Ok, I'll do that,
        one of the TVS diode is short, showing value on both test reverse and forward...
        Are you on the lowest scale on your analog meter? Around 200 ohm scale and is this reading off the board? Also, I think Stj is thinking you have a short from the power pin to ground.
        Does anyone have a schematic of the board?
        • bianchi77
          • Jun 2016
          • 1121
          All the resistors are 0 ohm ....
          • bianchi77
            • Jun 2016
            • 1121
            • bianchi77
              • Jun 2016
              • 1121
              yes around 200 ohms on the lowest scale on analog meter..
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Are you measuring the TVS off the board?
                • bianchi77
                  • Jun 2016
                  • 1121
                  yes I measured it off board....
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    So from the below post you said one of the tvs is shorted. The other is not? Do you have have the part number on the TVS? When you say shorted is that less than one ohm resistance? Have you but your leads together on the 200 ohm scale and adjusted the needle to read exactly 0 Ohms?
                    • bianchi77
                      • Jun 2016
                      • 1121
                      Ok, how can I test it ? with meter from front and back ? and see if it's open ?
                      how to fix it ? put a solder on it ?
                      • bianchi77
                        • Jun 2016
                        • 1121
                        I'll have a look and post it...
                        • bianchi77
                          • Jun 2016
                          • 1121
                          is it rusted or burned ? how to fix it ? put a solder ?
                          • bianchi77
                            • Jun 2016
                            • 1121
                            some magnified photos
                            • bianchi77
                              • Jun 2016
                              • 1121
                              looks like it's a dust or rust...I clean up with alcohol...
                              • bianchi77
                                • Jun 2016
                                • 1121
                                The shorted TVS code is AE
                                  The circuit does not need TVS to be in the circuit for the circuit to work, it is just a protection device, so if the TVS is removed does the board function? Low resistance is still present at the two EMPTY pads of the removed TVS?
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    So they look OK. I had thought the trace was missing.That does not seem to be the case in the close-up photos. Any time you have a question in the continuity of a circuit you can just Ohm it out to make sure it is connected. I would try as Bud M suggested. Look at the Voltage lines coming into the board to see what if anything happens to them. I would just connect the power lines first and observe the voltage. If that works OK then connect every thing up. Before you connect the power lines make sure the voltage is present on the connector.
                                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                      by momaka
                                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                      09-19-2021, 08:44 PM
                                      HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                      This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                      09-12-2024, 02:00 PM
                                      HP ProBook 450 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 450 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Seagate Expansion 1TB boardview and 450 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 08:10 PM
                                      HP ProBook 430 G7 + Seagate Expansion 1TB Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 430 G7 + Seagate Expansion 1TB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Seagate Expansion 1TB boardview and 430 G7 + Seagate Expansion 1TB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
