Are LED light bulbs supposed to get hot?
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Are LED light bulbs that go in one of those mini light sockets supposed to get hot? We have the baby's bedroom with a ceiling fan and three light sockets and we replaced the failed bulb and the working bulb with three LED bulbs. One bulb was completely missing from the socket. The socket is bad. It's falling apart.
    I gotta figure out how to replace that socket. But I'm wondering if there's some sort of short somewheres. Before I put the LED lights in, the other night, I went in and the two working lights flashed a couple times. Today, I go in, turn on the light and one of the two workings bulbs is dead. I didn't think LEDs were supposed to get very hot.
    The metal part that gets screwed into the socket is very hot as well. So hot, you can't touch it for very long.
    Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Are LED light bulbs supposed to get hot?
    Sounds more like arcing or corrosion causing heat buildup and failure.
    My 240v LED spots get mildly warm. My 12v LED desk light gets a bit warmer bit not hot to touch.
    • Spork Schivago
      • Mar 2012
      • 4734
      Before today, there weren't any LEDs in any socket. I just replaced the old school with the LED ones. Perhaps the old ones warmed up the base and the heat transferred into the LED ones? I'll keep an eye on it. I do worry about the wiring sometimes. They said updated wiring, so you know what that probably means. I know the updated gas lines were very, very wrong.
      • diif
        • Feb 2014
        • 6978
        • England
        Possibly. Remove the non LED bulbs amd you'll find out.
        Depending on the fitting and the way they are wired its not advisable to mix types of bulbs.
          • 30977
          are you using a dimmer?
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            I guess I would open up those sockets and look at them and measure the resistance.
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              All the led's I have, have a metal base as a heat sink. Some even have flutes in the metal. It's not for the led but for the electronics in the base.
              sigpicThe Sky Is Falling
                • 30977
                no, it is for the led's
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  For LED bulbs that get hot at the base, I would make slits or at least have a tiny fan! Just like a monitor!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    I wasn't mixing the bulb types. Sorry if I was unclear.
                    There were two non-LED type bulbs but three sockets. One socket was empty (because it was broke, but we didn't know that at the time). Today, one of the two bulbs blew, so I removed all the bulbs and installed three LED type bulbs.
                    After a while, we went in there and checked the bulbs, they were nice and cool. I mean, there was a little warmth but not like before, so I'm pretty sure it was the heat from the old bulbs that warmed up the socket and the sockets heated the new LED type bulbs.
                    Tomorrow, I'll keep an eye on it. If it gets hot again, we'll know there's a problem somewheres.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Nope. No dimmer.
                      I want to pull the switch and see if they installed the wires around the screw or if they put them in the back. Do you know what I mean?
                      We have a switch in the bathroom. I haven't checked to see if it's live or not yet. But wires are hooked up to it. What does it control? From what we can tell, absolutely nothing. Nothing in the attic, no lights in the bathroom, no outlets in the bathroom, not the fan in the bathroom. The faceplate is attached to the switch but the switch isn't connected to the box, so we can see the wires.
                        • 30977
                        underfloor heater?
                        maybe wires under the tub for a never-fitted air-pump?
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          underfloor heater?
                          Upstairs, it's just a shower, the tub / shower is downstairs. But I never thought of that, heated floors. That'd be really cool. I would have thought that'd be a big selling point though and the owners would have mentioned that. We'll test it out though. First thing I'll do is see if the wires are live.
                          This switch, it's right next to the toilet. I went in the attic and looked for a wire coming up and didn't see any in that area. I thought maybe it ran up there. There's a balcony that we have that you get to through the upstairs bathroom. I thought maybe they were going to add a light out there, but why put the switch next to the toilet and not next to the balcony door?
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            The wires are hot. The wire that the switch turns on and off, that runs up through the work box or whatever you call it (the blue box that the switch screws into). It doesn't run down, it runs up. Maybe it's going into the ceiling or one reason or another. Or maybe they just punched the top part of the box out and ran it down to the floor, instead of just punching out the bottom part of the box. I doubt that though.
                            There's insulation in the attic. Maybe I should go back up and take a closer look. Maybe the wire runs to some outlet up there or something that I didn't see.
                              • 30977
                              conect a lamp across the switch to see if there is a load.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                I'm not following this logic Stj. Turn on the switch and just connect a lamp between the two hot wires will somehow tell me if there's a load? Can't I use the multimeter for this?
                                • rhomanski
                                  nowhere man
                                  • 5157
                                  • U S of A
                                  Okay, I thought it was the electronics. None of my led's get hot that I can get to. Only those are glued together with a cover on them.
                                    • 30977
                                    with the switch OFF, put a lamp (40-60w) between it's input and output terminals.
                                    if it lights then something is drawing current through it.
                                    something else it could be, a heated towel rail.
                                    i had forgotten about those stupid things.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      A secret door to a batcave ? or a towel rail as stj suggests.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        I think I understand. The lightbulb will act as the switch, right? If there's no load on the other end, nothing will light...makes sense. Thanks!
                                        • ezenia
                                          LUMIMAN Smart Bulb IC ID?
                                          by ezenia
                                          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                          04-28-2025, 05:56 PM
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
                                          09-06-2024, 08:40 PM
