Common capacitors values?
  • tonyynguyen
    • Aug 2008
    • 20
    • us
    Hi, I'm thinking about stocking up on capacitors to have around. Recently I been recapping about 4 motherboards a week along with several tv's. I hate ordering and waiting for the caps to come in, I rather have a stock of common capacitors values for quick access when I need them. (electrolytes)
    So, What are some common values that you usually find on motherboards and television sets?
    Thanks..
  • ant3202
    • Jun 2006
    • 274
    • Singapore
    Re: Common capacitors values?
    470uf 6.3V
    1000uf 6.3V
    2200uF 6.3V
    3300uF 6.3V
    i think overall all those I had used the most for mobo recapping .... but note that there are more...
    • arneson
      • Sep 2005
      • 1267
      I'm finding the need for the higher voltages, 240 to 400v.
      Jim
      • Acerman123
        MSI K7T Pro2 Ver1 - capacitors have higher values?
        by Acerman123
        Trying to fix this board, MSI K7T Pro2.
        All Tayeh capacitors showed either as damaged or with uf values which were faf from what they should be so I have replaced them and all other capacitors except those big ones near CPU.
        The motherboard powers on but doesn't post. My PCI bios code reader will most of the time dsplay some some kind of code if there has been no power to board for a while but I don't think those codes mean anything in this situation. If I power off the board and try powering it on the second time the code reader usually doesn't show anythin. Unplug...
        08-12-2023, 10:00 AM
      • qwerty99
        Xbox 1.6 Motherboards and Polymer Capacitors
        by qwerty99
        Hello!
        I need to change the capacitors on my three original Xboxes.
        Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
        The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
        The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
        I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
        06-26-2022, 12:53 AM
      • amelbye
        degradation of solid state capacitors in motherboards?
        by amelbye
        Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
        Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
        Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
        I have already replaced the PSU.
        The board is a gigabyte x79 ud3....
        11-06-2022, 10:35 AM
      • Lef de art
        Different capacitors in the sassi and different values in the schematic !
        by Lef de art
        Hello guys.
        Recently i finished my first restoration in a 61 years old tube reel to reel recorder (Geloso G258) .
        Thanks God the process ended positively and the recorder works again very good.
        In this process i met a big problem by trying to figure what value in capacitors to use.
        I say this because all the capacitors excluded the electrolitic had different values from the capacitors in the sassi !!!
        Not one or two capacitors. It's about 12 capacitors !!!
        For sure i have the correct schematic.
        At the end i have used...
        11-03-2019, 04:22 PM
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
