soap opera effect in proscan pled 5529a 55 inch
  • khawer
    • Nov 2014
    • 7
    • pakistan
    hi guys
    is there any chance to turn of soap opera effect in roscan pled5529a 55 inch led tv..there is no such option in the menu..at menu i apply 1147 it opens
    a service menu there also isnt any option to turn soap opera off..any one help plz...i've tried proscanvideo.com,curtisinternational many other forums couldnt get anything
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: soap opera effect in proscan pled 5529a 55 inch
    This is your thread from 2014 ive also had a look and cant see any information on how to turn soap opera effect off
    https://www.badcaps.net/forum/showthread.php?t=42061
    • jeewantha
      Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
      by jeewantha
      Dell Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
      I already write 2 bios files. For both files it is not on.
      Only light up top cover LED..
      Machine Model : Dell Venue 10 Pro 5055
      Service Tag: GWV0G32
      Board Model Number : SILVERTON MB
      14238-1
      WX4XD
      Please help to fix this problem. ...
      06-22-2024, 09:54 AM
    • Mark R
      Does Changing Out Caps In A Tuner Effect FM Reception
      by Mark R
      "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
      I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
      Any Thoughts?
      06-11-2024, 07:04 PM
    • alessa
      medion MD31505 BE(vestel service mode) Distortion problem moving element
      by alessa
      I noticed a problem,
      There is a distrtion around the moving elements due to the movement interpolation (soap opera effect) which is not very well managed.
      my problem is not the soap effect which doesn't bother me at all, it's just this kind of pixel / distortion effect around moving objects or actors. I ask this question because I think it could be adjusted via a service menu or firmware.
      I managed to access the service menu and I do not really see what to do to improve the thing.
      I find it quite disappointing coming from a television from...
      05-03-2020, 03:39 PM
    • x_orange90_x
      Samsung UN50M5300AFXZA white strobing effect
      by x_orange90_x
      I have this un50M5300AFXZA that's exhibiting some strange behavior. When powered on it displays white with some horizontal lines, then goes to a vertical strobing from the center of the screen to each side. I've never seen something like this before, but I'm thinking it could be the tcon or main board. The behavior and patterns are consistent across both sides of the screen, so I don't think it's a panel issue but I could be wrong....
      10-30-2025, 04:29 AM
    • Briesmith
      BENQ GC2870 Floodlight effect from left hand edge of screen
      by Briesmith
      I have attached an image of the screen showing the problem which is that I see a sort of floodlight effect shining on the screen from the upper top left edge. I think the image shows the defect better than I could describe it but I would be happy to add any further detail if that would help anyone trying to help me.
      If you have seen this problem before or just know what it is from experience/knowledge etc I would be very grateful if you could pass on whatever it is I can do to fix it.
      Many thanks
      Brian...
      04-08-2022, 05:41 AM
