Samsung UN50M5300AFXZA white strobing effect
  • x_orange90_x
    • May 2015
    • 798
    I have this un50M5300AFXZA that's exhibiting some strange behavior. When powered on it displays white with some horizontal lines, then goes to a vertical strobing from the center of the screen to each side. I've never seen something like this before, but I'm thinking it could be the tcon or main board. The behavior and patterns are consistent across both sides of the screen, so I don't think it's a panel issue but I could be wrong.
  • howardc64
    • Jun 2017
    • 682
    Tried disconnecting left and right panel flex one at a time to see if either 1/2 of the panel has the error? On most Samsungs, require jumper FB_TRDY_1 pin.
    https://www.badcaps.net/forum/troubl...el#post3686471
    • x_orange90_x
      • May 2015
      • 798
      I will check that out. I did try to disconnect one at a time and each will display a solid white side while the other has that strive effect. I did not have anything jumped tho, so I'll look into that.
      • howardc64
        • Jun 2017
        • 682
        Does main have SPDIF light? when thats on, it usually means main mostly booted okay. Also does main make UI sounds? If so then smarttv OS is running.
        I guess check t-con inductors for voltage rails to see if they make sense.
        • Boardview and Schematic Bot
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
        • tech9pc
          Samsung QN65Q80AAFXZC QLED TV has a white vertical Bar
          by tech9pc
          Hi all Happy Holidays! Was just wondering if you think this white vertical bar would be fixable. Maybe bad TCon or ribbon cable? Contemplating trading a 50 inch Hisense 4K Roku for the Samsung but might get burned lol. The Samsung is model QN65Q80AAFXZC QLED TV has a white vertical Bar. Any thought appreciated. Thanks.
          12-24-2023, 11:28 AM
