Diode testing on meter gone bad?
  • knoxrebel
    • Oct 2009
    • 168
    Hey guys while troubleshooting a monitor yesterday I tried to test some mosfets and had some false results with my extech 330 multimeter. In diode mode it only puts out 1.5v while my junk drawer meter puts out ~2.5v. Am I doing something wrong or is my meter on the fritz?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Diode testing on meter gone bad?
    Originally posted by knoxrebel
    my extech 330 multimeter. In diode mode it only puts out 1.5v. Am I doing something wrong
    The manual, page 19, is your friend.
    --- begin sig file ---
    --- end sig file ---
    • Baste
      MBR3045CT and SR3045LCT Schottky diode testing help.
      by Baste
      Hello experts,
      Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
      Aneng ST182 Meter.
      Diode mode.
      MBR3045CT:
      Diode mode
      Pin 2-1 - 0.150v
      Pin 2-3 - 0.150v ...
      10-21-2025, 06:14 AM
    • MalodicOne
      macbook pro 820-02100 5v 0 amp
      by MalodicOne
      Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
      Tested all CD3217 and RAA489900:
      UF400
      PP3v3_UPC0_LDO- 3.48v, .473 Diode
      PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
      USBC0_CC1- 0v, .455 Diode
      USBC0_CC2- 1.66v, .454 Diode...
      07-25-2025, 10:49 AM
    • Scruit
      Diode mode testing of motherboards question
      by Scruit
      (I am self-taught in electronics over 20 years as a hobbyist, but I lack some of the fundamentals that folks who went to school for this would know... so please bear with me as I get deeper into this new hobby of retro computing...)
      I'm familiar with diode mode in that it produces a small voltage between the leads and displays the the amount of voltage drop when the leads are connected... however....
      Why do the board repair folks always put the positive lead to board ground and use the negative lead to probe the board itself? My intuition would be to put the negative...
      04-10-2022, 10:16 AM
    • asr
      Finding replacement diode iPad Pro 3rd gen A1701
      by asr
      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
      07-09-2024, 06:24 PM
    • unimatrix93
      TV backlight zener diode
      by unimatrix93
      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
      The led strips has 9 6V leds.
      02-10-2025, 12:13 PM
