Re: Need help identifying smd
Q33 Collector may be used for driving other circuit beside Q12 otherwise Q33 is not needed since the two transistors are acting as double inverter circuit.
Why is Q33 biasing Q12 anyway? I mean is Q33 needed if Q12 turns on when base is .6v which is could get without Q33?You can short B to E of Q33 which will turn off Q33 so the Collector will rise to bias on Q12, this will force Q12 Collector to be LOW which is the condition you want as indicated in post 1 (drops to 0v (this is when the display powers on as it should)).
You have control signal problem some where on the board.Leave a comment:
Ok so here's a quick rundown of operation. Just remeasured to simplify
Power off/standby
Q33 base - .22v collector 0.22v
Q12 base - .22v collector .22v
Power on (display on)
Q33 base - 0v collector .62v
Q12 base - .62v collector 0v
Power on (display stays off)
Q33 base - .68v collector .0v
Q12 base - 0v collector 5vLeave a comment:
I suspect that even if you forced the display to turn on, it would remain blank or indeterminate. That's because the micro that switches the transistor also generates the information for the display (unless there is a slave micro).Leave a comment:
Yeah sorry that was a typo I edited it to say "When it does turn on Q12 gets .6v from Q33"
So it seems like Q33 signals Q12 to turn on but it's not doing that every single time. Still would be something else? Could I bypass Q33 so .6v goes directly to Q12?Leave a comment:
'But when base of Q33 gets .6v with power on command, there's no voltage to Q12 when the display doesn't turn on.'
So Q33 is turned on because it has 0.6V to Bias it on, so the Collector of Q33 (which is connected to the Base of Q12) will be LOW which turns OFF Q12 so the Collector of Q12 will be HIGH (5V), so that is what will happen.
'When it doesn't turn on Q12 gets .6v from Q33'
So when Q33 does not get the 0.6V to turn on, then the Collector of Q33 will go high to provide the 0.6V to turn on Q12 which will make the Collector of Q12 to be LOW (0V).
So the circuit is doing what it is being told to do, so for you to get 0V at the Collector of Q12, the Q33 must be stopped from getting the 0.6V command signal to turn on.
Q33 is getting command from processor or what ever that generates the command signal to do what it suppose to do.Last edited by budm; 04-19-2016, 12:21 PM.Leave a comment:
So Q33 won't be the fault? Base of it connects to a resistorLast edited by caphair; 04-19-2016, 12:14 PM.Leave a comment:
Yes there's 0v at base of Q33 before pressing power button. When pressed base of Q33 gets .6vLeave a comment:
If Q33 has steady 0.6V between B and E then it will be staying on so the Collector will stay LOW all the time, so Q33 is being told to turn ON, are you sure that the Q33 B-E Voltage is not changing state?Leave a comment:
Q33 seems to be connected to the base of Q12 and when powered on there's .6v on base of Q33 but nothing on its collector remains at 0v. Would Q33 be the culprit?Leave a comment:
Ok so the bottom pin is the base and I should trace what's connected to the base to find the problem?Leave a comment:
That means that Transistor (NPN) is working, when it has 0.6V to bias on the Transistor, the Collector (Top pin) will swing LOW, when there is no Bias (0V) the transistor will be off so the Collector Voltage will swing high (5V).
So it gets the command signal from some where.Leave a comment:
When it powers up as it should yes the bottom pin is .6v
When it doesn't power up the top pin is at 5v and bottom as 0v
What does this mean?Leave a comment:
Check the Bottom PIN to see if it change state and the reading is about 0.6VDC.Leave a comment:
Hi guys I've been working on a dual din radio for a car.
Problem is sometimes turns on sometimes down. I traced the tft_on line to a smd transistor? Has markings "halg"
What I noticed is there's 0v on top lead then when powered on it momentarily goes high to 5v then drops to 0v (this is when the display powers on as it should)
When the display doesn't turn on the top lead goes high to 5v and doesn't drop stays high at 5v
Would this part be the problem or something else? I've included a picTags: None
by sam_sam_samI have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
I tested the battery cells there are installed right now and they are testing good with no issues that I... -
by DynaxSCHi Folks
I'm looking for a extreme high current short killer solution for a reasonable cost.
I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
After taking off the socket, the shorts dissappear again.
The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...10-15-2024, 10:13 AM -
by harpIs there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
AD7276, AD7277, AD7278, AD7274, AD7273
The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:32 AM -
- Loading...
