Re: Need help identifying smd
Ok I have a question. When the display doesn't come up on Q60 there's 1.92v on the base and 1.25v on emitter and collector. When display comes on there's a difference of those voltages on the collector at .67v
Does this show something wrong with that transistor or something else?
You can esily find out if the Transistor are switching as it should or not by check the DCV between E and B, and E and C.
if E and B changes state then E and C will also change state.
You should look up on how Transistor operate.Leave a comment:
The end of R324 that connects to base of Q60 has 1.95v when the display doesn't turn on. The other end of R324 has 5v
When the display come on, base of Q60 drops to .70v 5v stays same on other end of R324. Is it normal to have that big a voltage drop across a resistor?
I wish I could figure out what's not switching every single time.Leave a comment:
The Base of Q60 is connected to R324, another end of R324 goes to the VIA to connect to what ever, the board may be more than 2-layer board.Leave a comment:
Ok here's the area where Q12, Q33 are. There's another transistor Q60 that feeds 1.5v to base of Q33 through R193. It's base isn't connected to anything though, how does that work?
It's emitter connects to R154 which goes out to a pin that I traced to a chip right under the DVD drive. I'll post a pic of that next as my phone only allows one pic per post. I'm not sure if this is power for the DVD drive or linked to power on for the LCD?Leave a comment:
Where would the main processor most likely be located, the circuit board with DVD drive/psu or circuit behind the LCD assembly?Leave a comment:
What about an FCC ID? Sometimes there are useful documents in the FCC database.Leave a comment:
Is there a PDF manual for this thing?Leave a comment:
I'll provide part numbers of major ICs when I'm home but it's an Absolute DD-3000ABTLeave a comment:
Can you give us the part numbers of the major ICs and the model number of the device?Leave a comment:
So just for reference, how does a processor turn an LCD display on?
Does it first send backlights signal then once that's on it turns LCD display on?
Doesn't make sense why if it's on it stays on but soon as it's turned off it won't come back on unless you keep tryingLast edited by caphair; 04-19-2016, 04:55 PM.Leave a comment:
KTC3875-GR / BR3DG3875M, KEC / Blue Rocket Electronics, NPN transistor, 60V 150mA, hfe = 200-400, marking HALG or ALG:Code:VCC 5V = power on + 0.22V = standby | .---+--. | | .-. .-. | | | | | | | | '-' '-' display | | o----+ Q12 | | | 5V = OFF \| | 0V = ON |----+ <| | hi = OFF | \| ___ lo = ON | Q33 |--|___|---o | <| from micro | | '---+--' | === GND
https://cdn.badcaps-static.com/pdfs/...ef4b37225e.pdf
https://cdn.badcaps-static.com/pdfs/...2ec8d6d3bf.pdfLeave a comment:
Or the processor detects fault or what ever the exact problem is so it shutdown that control line, I do not the details of how this unit is designed to function, that is why you did see the Voltage on the Collector of Q12 did the toggle LOW and HIGH due to activity of the processor output that feeds Q33 Base.Leave a comment:
So the processor is the problem. Can't be corrected without replacing the processor?Leave a comment:
No, you do not want to do that.I shorted B to E of Q33 and now it powers on every time with the difference that the display turns white briefly before the logo and screen pop up. Is it safe to continue using this way?
Also didn't think to short B to E of Q33 I was thinking shorting B of Q33 to B of Q12. Would this yield same outcome as now?
The whole purpose of switching those transistors is to have proper sequencing on so you'll not see what you are seeing. Like I indicate, you have bad command signal going on with the processor.Leave a comment:
Spoke too soon. Now I just get a white screen when turning on with B to E shorted on Q33Leave a comment:
Also didn't think to short B to E of Q33 I was thinking shorting B of Q33 to B of Q12. Would this yield same outcome as now?Leave a comment:
by sam_sam_samI have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
I tested the battery cells there are installed right now and they are testing good with no issues that I... -
by DynaxSCHi Folks
I'm looking for a extreme high current short killer solution for a reasonable cost.
I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
After taking off the socket, the shorts dissappear again.
The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...10-15-2024, 10:13 AM -
by harpIs there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
AD7276, AD7277, AD7278, AD7274, AD7273
The AD7276, AD7277, AD7278, AD7274, AD7273 are 12-bit/10-bit/8-bit, high speed, low power, successive approximation analog-to-digital converters (ADCs), respectively. The parts operate from a single 2.35V to 3.6V power supply and feature throughput rates of up to 3 MSPS. The parts contain a low noise, wide bandwidth track-and-hold amplifier that can handle input frequencies in excess of 55 MHz.
The conversion process and data acquisition are controlled using CS and the serial clock, allowing the devices to interface with microprocessors...-
Channel: Common Parts Library - Datasheets
10-07-2024, 05:32 AM -
- Loading...
