is there any way to modify a USB to write protect it.
Modify USB Drive
Tags: None
Re: Modify USB Drive
It depends: if your usb device is a flash drive a.k.a. pen drive without the "write protect" switch (the wide majority hasn't it), you should have the datasheet regarding the controller since most of them has a pin used for the switch.
ZandraxHave an happy life.Comment
The drive that i want to modify is a Corsair Flash Voyager 1 GB,it uses a Prolific 2518 controller,i have seen its data sheet it does have write protect pins.How can i use it??Comment
Originally posted by keyboardcowboyThe drive that i want to modify is a Corsair Flash Voyager 1 GB,it uses a Prolific 2518 controller,i have seen its data sheet it does have write protect pins.How can i use it??
Try soldering on such a small chip is a risk: you may damage your drive, the usb port you connect it and lose all data on it. According to datashet, the controller supports the creation of "hidden" partitions with a Prolific utility (Prolific MFG kit): try looking for it. It's likely to be a Windows tools: hidden or secured partitions are unreacheable on all other operating systems.
OTOH if you don't mind risking damaging your usb drive, then backup all data and open it: I don't know how the WP pin should be connected nor I tried soldering on my drives, but if I were you I'd short SM_WMPIN to a ground pin or, even better, use a small switch to open and close the short circuit. If it does work, congratulations; if it doesn't and it smells burn ... controller gone at 99%. It's a risk.
ZandraxLast edited by zandrax; 06-29-2008, 03:33 PM.Have an happy life.Comment
i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...-
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
This specification for the HP EliteBook 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...09-06-2024, 08:50 AM
This specification for the HP EliteBook x360 1040 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 1040 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...09-06-2024, 08:50 AM
- Loading...
