HDMI Spliter?
  • ivtec
    • Dec 2008
    • 1967
    HDMI Spliter?
    Hi guys; i bought an HDMI spliter to connect two TV's,from my Roku 4,
    the LCD with HDMI cable works great, but my other Sony TV with DVI input does't work with HDMI to DVI,
    but my Sony works great if i plug hdmi to DVI strait from the ROKU4.
    http://www.amazon.com/J-Tech-Digital.../dp/B00CUMJRLY
  • lilo2400
    Sony PS5 EDM-020 MIssing voltages near HDMI encoder
    by lilo2400
    Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
    Thanks in advance
    09-02-2025, 03:58 AM
  • BubbaW
    Sony KDL 55HX800 Lightning-HDMI's bad
    by BubbaW
    Last week our home was hit hard by lightning, so much so that 4 transformers on our street were blown out.
    Items lost....DirecTV box, Cable TV box and initially Sony 55"....all inputs hooked up via HDMI. We have since purchased new set but wanted to at least try and see if this TV can be fixed.
    Initially while T/S, found all inputs fine except T-Con_ON = 0VDC
    but front panel had 3 red blinks. Yesterday took Pwr Supply and Main Board out to check for any noticeable failures. Coincident or not, after replacing both boards the TV started working fine...
    08-21-2022, 08:14 AM
  • aliougm
    Marantz SR4003 AVR HDMI board issue, seeking for help
    by aliougm
    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
    Connection as below:
    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
    If I bypassed AVR then HDTV screen color be good.
    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
    I replaced all...
    04-30-2022, 12:21 PM
  • Ritchie_Uk
    Sony PS4 component Missing, near the HDMI Port
    by Ritchie_Uk
    Hi there
    A Sony PS4 came in for "No Video" and it seems there is a component Missing, near the HDMI Port.
    The Component circled in Red
    1. Was this just a Component Missing from Manufacture please?
    2. It is a straight forward Port Replacement, or do I need to be aware of anything else?
    3. Any Schematics or Board Views available?
    Any Advice is greatly appreciated.
    Stay Safe !!...
    05-22-2023, 06:12 PM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
