Troubleshooting electronics...
  • paulof
    • Jun 2008
    Other than capacitors what are common components that usually die off ?
    Are resistors ever likely to go bad ?
    Is there other common signs to look for bad components other than capacitors ?
  • medamotcha
    • Jun 2008
    • 66
    Re: Troubleshooting electronics...
    look for burns in the board ..is the most common....and look for cracks in the dieodes...the resisers you have to check the resistance or omes to see if bad.but im not a super tech...i know the basics...smell the board see if and were if burn't
    bad caps make me crazy
    • barefoot
      • Aug 2008
      I agree, First look for blow fuses. Then look for or smell for anything that shows damage. This can be a bubble on a transistor or computer chip or faint discoloration to blown caps. Also look for tail tail signs of oil under caps. Many repairs are just the one bad component. If it is not obvious check for bad solder joints with plenty of light and a magnifying glass. I things are not obvious, then obtain and trouble shoot with the schematic. Good luck.
      • chipper
        • Aug 2008
        • 95
        While there are many tests that can be performed by a technician , the first really good tool to have is a multimeter to test the numerous parts of course , but looking can't always solve anything.
        More times than not , there are no tell-tale signs of damage in electronics , as miniturized circuits are hidden from any magnification level. Serious problems should be looked at , if there are NO SIGNS , by someone who knows the particular component that you have. While dealing with the manufacturer can be the best thing , it is not always going to reveal the response that is usually expected or sought.
        Resistors do go bad but are usually coupled with some very obvious circuit overload damage. Burning. From experience I have learned that "mixed" component parts are one tell-tale sign that the unit in question was not actually built by any company in particular IE : Sony , Toshiba , Hitachi , and others , if you see more than 2 manufacturers names on the small main chipsets , chances are the entire board is racked with compatibility problems which were accelarated by 1 failure or another.
        These can be the most costly and difficult repairs due to a lack of reliance upon any 1 manufacturer specifications. If the circuit board in question is more than 5 yrs. old , it falls into this category. While subsequent units of the same type , have no names that can be quoted or sought. Like the Hitachi symbol on a Sony VCR unit. It already has 2 right there. Further looking will definately reveal many more , but the chipsets are the factor which I find unbelievable to expect to be working together.
        On the contrary , if you only see 1 major brand name on chipsets , chances are the unit is of quality and not a mixed up compilation of circuits that has failed due to any sort of incompatibility. If these different chipsets are soldered together on 1 or 2 boards , it seems that nothing resolves the unit's problems and is usually called a lemon. Especially if someone has improvised with obviously differing brand names or parts on circuit boards. Their datasheets can explain some things but are complicated and not much help to those who do not understand schematics.
        One of the worst signs you can come across is the fact that the main power supply is not working , does not heat up , or seems dead. That could mean someone has made that particular unit work before when it broke down , somewhere along the line. Refurbishing since 2000 has become a common practice and may have only been a temporary fix. These can lead to power supply failures because the integrated circuits are not rated to allow any tampering beyond their original specifications. Killing the power supply eventually. Don't forget that when a system of any kind runs on an overheating power supply as a result of problems it ages much faster and could have multiple problems internally. Fixing 1 thing will lead to another failure in alot of cases. Base your decisions on the condition of the power supply , as the wrong fuse is a good sign that the unit has had problems and is poofed.
        Replacing a power supply can sometimes make the existing problem come to light , and burn out the supply in a month or so. It's a good guideline to look for similar parts all over the board and the unit. Hope this helps.
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • Awsmessymail
          Vizio E701i-A3 backlight only and now no backlight
          by Awsmessymail
          Hello all,
          I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
          I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
          As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
          02-13-2024, 11:04 PM
        • dreamlayers
          Weird clipping on Logitech Z-10 speakers
          by dreamlayers
          I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
          05-22-2025, 11:41 AM
        • Hypersapien
          Artist seeking to tinker with electronics safely
          by Hypersapien
          Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
          When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to...
          10-22-2023, 01:31 PM
        • siccfix
          HP Omen 15-ek0013dx - Odd 4-Zone RGB Issue, Replacing Entire Keydeck Didn't Fix It
          by siccfix
          Replaced the keyboard+LED backlight+topdeck unit with a completely assembled aftermarket part a few months ago due to failing keys (Spacebar, X, R; seems to be a common issue for 2020 model). I thought this would also fix my RGB backlight issue but the problem remains, actually it got worse, so it has to be a failing part on the mobo itself. The middle RGB zone can no longer light up blue and is instead stuck on green, even if all kb backlight is turned off that zone stays lit..
          Does anyone know what part number the IC labeled UI3 is? Seems to be some kind of LED controller chip....
          04-24-2025, 08:54 AM
