Capacitor bank
  • Eliminator91
    • Apr 2016
    • 5
    • australia
    Capacitor bank
    hey guys just wanting a few questions answered, is there a way to measure how much uf? would be in amp hours? cause i wanna make a capacitor bank but im trying to work out if its worth it for me
    thanks for reading
  • ZnsaneRyder
    • Oct 2015
    • 88
    • Merica
    Re: Capacitor bank
    Measure uf of most of your individual caps, calculate and average for each cap, then multiply the microfarads. Label your cap bank with the total microfarads.
    • Eliminator91
      • Apr 2016
      • 5
      • australia
      Re: Capacitor bank
      each cap will be 16v 1000 uf, thats what im thinking atm as a starter tester kinda phaze can get 50 for 4$ so its not a huge investment im just curious how manyamp hours id get im looking to replace a 12v, 1.9 amp hour battery if any1 has an equasion plz post in its raw form i should be able to work it out from there
      thanks
      • Eliminator91
        • Apr 2016
        • 5
        • australia
        Re: Capacitor bank
        also how many would be safe to wire together before the wires get too hot?
        i was thinking of just using the legs they have and just tacking them together but would it be better to use some thicker wire? is this more of a touch n go situation like just see how they stand up worst case scenario it just melts solder and fails? or can i pop capacitors trying it without wires? just random questions i know but all information helps greatly thanks guys
        • ZnsaneRyder
          • Oct 2015
          • 88
          • Merica
          Re: Capacitor bank
          I'm trying to help you, but you may need to study how capacitors work, and realize they will not store as much as you may think. Capacitors store SHORT bursts of energy.
          A LARGE 1FARAD (1,000,000uf) in parallel with a car battery will help the starter start quicker, but it WILL NOT WORK BY ITSELF.
          USE A BATTERY to check your starter.
            Re: Capacitor bank
            http://www.calctool.org/CALC/eng/ele...pacitor_energy
            http://www.electronics2000.co.uk/cal...calculator.php
            http://www.engineeringtoolbox.com/ca...er-d_1389.html
            http://www.dummies.com/how-to/conten...capacitor.html
            https://www.maximintegrated.com/en/d...n/supercap.cfm
            Cap is not the same as battery. The RC determine the charge/discharge time.
            Please study about the cap as suggested, complex stuff.
            • Eliminator91
              • Apr 2016
              • 5
              • australia
              Re: Capacitor bank
              thanks for the help i found the info i was looking for, yes i know capacitors store short bursts of electricity this is mearly a bit of fun for me lurning and generally experiencing it, i have so many dead devices i have pulled capacitors off i just wanna tinker atm but i did find 44,000 uf capacitors there expensive but now i know to look out for them :P if any1 else is interested in the info i found it at
              http://www.convertunits.com/from/uF/...re+second/volt
              http://www.translatorscafe.com/cafe/...ampere-second/
              thanks for noticing my post anyways guys if your interested chuck me a mail ill post some updates privatly on how it goes or if enuph interest and theres a relevent place on forum ill make a post
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
                HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook 800 Specification for Upgrade or Repair
                This specification for the HP EliteBook 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter boardview and 840 G6 + 20000mAh Blupeak USB-C Laptop Power Bank + Blupeak USB-C Magnetic Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with...
                09-06-2024, 06:00 PM
