I need some help identifying a crystal.
  • DCJack
    • Apr 2013
    • 26
    I am trying to fix a friends "bow string weight guage", basically an electronic scale that hooks on to a string. It slipped out of his hand when he was testing a bow and shot it across the room into a wall like an arrow. Everything looked fine but the unit won't turn on now.
    I took the thing apart and can't find any physical damage and all the components pass my DMM sniff test and from past experience I know that crystals can fail due to shock damage much more easily than other electronic components. I'm hoping to replace the crystal and be done with it because if it is the PIC that is damaged then he is screwed because there is no way in hell I am going to be able to get my hands on the programming to make a new one.
    The problem I am having now is that I can't figure out what the crystal is. I Google'd the only markings I could find on it and nothing of worth comes up. I also have no experience with PICs so I can't make any educated guesses as to what it could be. Any help or advice would be appreciated.
    P.S. I have attached pictures of the crystal, board, and the PIC.
    P.P.S. I am getting all the appropriate voltages and am assuming that the PIC is simply not turning on.
    • 31278
    Re: I need some help identifying a crystal.
    4MHz
    • DCJack
      • Apr 2013
      • 26
      Originally posted by stj
      4MHz
      Well that was quick, thanks. How did you figure that out?
        • 31278
        it has a 4, and most low-end pic's are 4MHz
        • fzabkar
          • Mar 2009
          • 772
          Does the crystal rattle when you shake it?
          FWIW, the PIC16LC925 is rated for frequencies up to 20MHz.
          https://cdn.badcaps-static.com/pdfs/...2576021b1c.pdf
          • DCJack
            • Apr 2013
            • 26
            It does not make any noise when I shake it, no.
            • jons
              Need help identifying crystal
              by jons
              Got VW Bosch ECU with rotted away crystal oscillator and can't find frequency for it, it drives Bosch 30302 chip for which there is also no any datasheet. Markings on it says
              453NDK9X.
              and there is nothing on internets about it that I can find....
              10-02-2024, 09:50 AM
            • pc_okay
              Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
              by pc_okay
              Hello friends,
              Its been a while, i wish you an happy new year 2025 !
              I have this laptop doesn't start, power light up a second when pluging USB-C charger.
              Laptop take 0.11A.
              All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
              I get no oscilation on XTAL 32.768 KHZ
              Battery is not charging but charging led is here.
              PCH heat at 30° approximatively. (with no heatsink)
              I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
              It's a 2 pins Crystal.
              01-13-2025, 09:26 AM
            • OakleyDAR
              Zotac GTX 1050 Ti Mini ZT-P10510A-10L Replacement Crystal
              by OakleyDAR
              HI,
              I'm looking to replace the 27MHz crystal on this board as it isn't generating the signal. I thought it would be easy to identify a suitable replacement as there are clear markings on the crystal, but it appears I was wrong as Google gives nothing. Bad photo attached, but it has X27.0000 and 16AP1 on the casing. It appears to be a 3225 package, but looking through suppliers there are lots of different things like capacitance, tolerance, active or passive, etc. that need to be considered. Could anyone help identify a suitable replacement please?
              Thanks....
              04-21-2024, 03:07 PM
            • AustinCER
              Need Help Identifying this LCD FPC for Dell G3 15 3590 Gaming Laptop
              by AustinCER
              I am in search for some help in identifying the LCD FPC. It is a connector for a plug-able eDP cable.
              Attached is a photo of the FPC.
              Model: Dell G3 15 3590 Gaming Laptop
              ST: 79QYJT2
              Thank you very much in advanced....
              11-03-2025, 02:55 PM
            • Keshenatech1
              Question on microprocessor crystal oscillator circuit
              by Keshenatech1
              I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
              02-26-2024, 11:05 AM
