Will replacing the capacitors fix this...
  • chipped
    • May 2008
    hi all,
    I bought a external 2.5" inch HDD case the other day and it has 2 plugs on it, 1 is a USB plug which provides power and data, the other is a DC in just incase the HDD cant be powered by the USB alone.
    Now when I plug the USB by itself into a front USB port on any computer it just wont power up, you can hear the drive drive trying to turn on rapidly and the LED flashes on and off. If I plug the USB by itself into any back port (mobo port) of any computer it works fine.
    So i was thinking if i replace the standard capacitors with some bad boy big ass ones will it increase my chances of starting up from the front USB using the USB cable alone. It almost powers up using the front USB with just the USB cable, just a tinge more and it will start up I reckon.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Will replacing the capacitors fix this...
    drive exceeding the 500ma limit?
    if the box is stable and no blown caps seen its likely tripping the ocp on that port.
    • chipped
      • May 2008
      i tried 2 different Hard drives in the same case. My mates USB hard drive works fine on my case though, one plug on the front port.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Welcome chipped.
        That's not a capacitor issue, but a limit on current a peripherical can draw from USB: 500 mA at 5V, a max power of 2,5 W. Most notebooks and mainboards respect this limit, but some desktop motherboards may allow draws up to 1 A. Front ports are "weaker" form this point: they usually respect the limit.
        Some drives aren't power hungry and can be powered through a single usb cable: they are usually 2.5" 4200 rpm disks (saw some old Toshibas).
        Others require more power, so they are shipped with a Y-shaped USB cable (one end for data and power, the other for power only) or are battery powered (rare). 3.5" disks have always an external psu because they draw much more and require both 5 and 12 V, while 2.5" use only 5 V.
        Zandrax
        Have an happy life.
        • gdement
          • Jan 2007
          • 690
          Powering external drives from the USB port makes me nervous about damaging the port, especially with laptops. I'd definitely use one of those Y-adapters, whether you seem to need it or not.
          • competition
            Replacing capacitors in Evga PSU
            by competition
            I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
            Yesterday, 11:12 AM
          • Tyran
            Replacing capacitors on a 12v 5000w Pure Sine Inverter .
            by Tyran
            Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
            04-22-2022, 08:26 AM
          • yuzupatogik
            Help with replacing Capacitors on Altec Lansing ATP 3
            by yuzupatogik
            I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
            I can't find datasheets for the Samxon in any of the following variants:
            10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
            02-14-2025, 04:11 PM
          • frannyjunk
            Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
            by frannyjunk
            Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
            Any thoughts if OK to use these higher voltage capacitors?
            11-04-2021, 05:59 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
