I'm wondering how the brightness works on LCD tvs. Is is that more of each pixel is exposed?
Difference backlight and brightness?
Re: Difference backlight and brightness?
The actual LCD is like a sheet of glass, transparent.
When a pixel needs to be white all three sub pixels (red, green and blue sub-pixels) are completely transparent and let the light from behind this glass go through. When you want a black pixel, all three sub-pixels are turned on completely so they're blocking 100% of the light.
Behind the LCD, there's several thin sheets of material that have purpose of spreading (diffusing) the light coming from individual leds and spreading it across the whole lcd screen. Then there's the individual leds spread all across the back side.
With computer monitors, sometimes the leds are on the edges of the screen, but with large tvs they're often all across the back.
The TV or monitor can then adjust how much energy is sent to the LEDs to adjust the overall brightness.
That's the most basic stuff, monitors and TVs have several other tricks like turning on and off individual pixels to have a finer brightness adjustment, or better contrast.
You can see here the insides of a lcd tv : https://www.youtube.com/watch?v=hh3z_dkkcUM
It's a repair video but if you're not interested in the diagnosis, you can skip to around 10:00 where he starts to take it apart and then you'll see the insides. On this one the leds are on the edge of the screen.
In this other repair video, the leds are all over the back of the tv , skip to around 5:00 if you're impatient : https://www.youtube.com/watch?v=Bf5T2wwtydYLast edited by mariushm; 12-07-2015, 08:39 PM.
by pniHi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
by ohrenI raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
The setup is basically:
Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
Transistor is switching the 3.5 V supply on the power board.... -
by hollox123Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
1. Laptop keyboard doesn't work
2. The backlight on the laptop keyboard doesn't work
3. The x2 side LEDs (red) on the laptop don't work
The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
But I am strongly aiming that it is somehow a BIOS-related problem,... -
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 -
by signal.questI have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...2 Photos
- Loading...
